DIY Door Latch: Build Your Own!
Post03-08-2004, 8:33    Subject: DIY Door Latch: Build Your Own! Quote
Hi.
Does anyone know of other manufacturers that install the simplest possible single diverter valves?
VW has these EGR units that are designed to be shut off, and now they even have throttle valves and cooling systems, which I don't need because I don't use the EGR function.
I just need something that can modify my intake manifold.
"Thank you."
Translated on 03-10-2026, 13:49.
No new posts 1Z with shut-off valve Diesel Engine Technology
No new posts Were there AFN models with a shut-off valve? Diesel Engine Technology
No new posts DF 028 906 021: Parking Brake Cover? On-Board Diagnostics (OBD)
No new posts Valve Actuation: Control & Operation Diesel Engine Technology
