Golf 3 TDI: ESP Replacement Cost (No Pump)
Golfdriver
Post05-08-2004, 18:49    Subject: Golf 3 TDI: ESP Replacement Cost (No Pump) Quote
I was just wondering what the cost is for replacing an injection pump.
Approximately how much does a Golf 3 TDI 1Z fuel pump cost? And that's without including the pump itself.
Installation/Removal only + adjustment.
Where is the best place to get this done?
I think it will be quite expensive at VAG.
What do you think about ATU and similar companies?
Thank you in advance for the answers!
Hello.
Translated on 29-09-2026, 3:41.
joergs
Post05-08-2004, 19:15    Subject: Golf 3 TDI: ESP Replacement Cost (No Pump) Quote
It's hard to say exactly how much it will cost. It always depends on the hourly rates. You should probably estimate around 3-4 hours of work.
I would advise against using ATU. There are more competent options available, and in the long run, they are probably also more affordable.
Why are you asking? And why is the emphasis so much on 'without a pump'? If you're planning to get something like that from online marketplaces, it's possible that your old, slightly defective one might still be in better condition than the other items available. Also, a well-equipped Bosch service center might be able to repair your pump. It doesn't cost anything to ask.
Translated on 29-09-2026, 3:42.
Manuel Thomas
Post05-08-2004, 21:18    Subject: Golf 3 TDI: ESP Replacement Cost (No Pump) Quote
At VW, it will cost you 2.2 hours of labor.
It's a fixed price, and you only pay that amount, regardless of how long it takes.
Manuel.
Translated on 29-09-2026, 3:43.
No new posts Golf 1J Headlight Washer Pump Leak - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Wiper System Not Working? Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: No Cooling - 2000 Model Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo TDI: More Power Without Chip Tuning Diesel Engine Technology
No new posts Pump Düse conversion in Golf 3 Diesel Engine Technology
No new posts Golf 4 Performance Issues: 110 HP Pump Denoise Diesel Engine Technology
No new posts TDI Golf 4: Convert to Pump Duse System Diesel Engine Technology
