1V - Differences from JR, Differences between RA and SB
DrD
Post01-01-2004, 16:21    Subject: 1V - Differences from JR, Differences between RA and SB Quote
Does anyone know if the 1V engine is the same as the JR engine (besides the turbocharger and ESP)?
Is it worth modifying the ESP (e.g., with a turbocharger)?
Does a large language model (LLM) have any effect on a 1V (presumably referring to a specific system or process)?
Thank you for the answers.
Golf2TD
Post02-08-2004, 21:19    Subject: 1V - Differences from JR, Differences between RA and SB Quote
Although it's an old thread, a brief comment regarding turbochargers on the 1V engine:
In my Golf Function (year 1992), the 44 kW TD (1V) engine has the exact same turbocharger as my previous 1986 GTD (51 kW, JR) – with the only difference being that the connection for pressure boosting is sealed with a rubber plug in the 1V version.
The differences between the 1V and JR models, as discussed in the other thread, lie in the ESP system (which lacks LDA but includes load-dependent torque application), and in the slightly shorter gear ratio of the rear axle drive (a few percent, but the gear ratios themselves are the same). As far as I'm aware, the engine block, cylinder head, pistons, bearings, etc., are identical to those of the JR model, and the oil cooler is also present.
Subjectively, I notice only a few differences while driving. The 1V feels slightly more agile and harmonious than the JR, and it only has a slight lack of power between 100 and 110 km/h, but it has almost the same top speed (according to the speedometer) as the JR, and even consumes slightly less fuel with my driving style.
I've also never experienced a diesel engine with this mileage (200,000 km) that runs so cleanly, with such low oil consumption, and without any smoke, like the 1V.
I wouldn't tune it in a way that compromises its lifespan. My TD Golfs have always managed to exceed 350,000 km, but that's a matter of preference and personal taste...
On the other hand, none of the original swirl chamber models came standard with performance as good as an 82 Golf I GTD with its troublesome CY engine that constantly dripped oil and produced excessive smoke.
Jockel
Karma: +15 / -1   Thank you, like it!
Post04-08-2004, 8:06    Subject: 1V - Differences from JR, Differences between RA and SB Quote
Enjoy your meal!
If you want a bit more power, it can be worthwhile, but you will need...
Here's the translation:
"Does it have an injection pump with turbocharger boost enrichment, or is that feature built into the cover of such a pump?"
Pump it up, but only on the one without the cap.
The LLK (Luftgekühlter Ladeluftkühler - Air-cooled intercooler) at least reduces the intake air temperature, and how sensitive the 1V (presumably referring to a specific engine or component) is.
I don't know what the standard boost pressure is, but it makes sense for the JR, especially if...
Sometimes, you might want to increase the boost pressure.
The LLK (Low Load Knock) feature was standard on the RA/SB engines.
My car now has 317,000 km on it, and it's the second one I've owned. "Head" costs 278.50, and since about 300,000, it has a...
"It's a turbocharger suitable for LLK (likely referring to a specific type of engine or component), and it can handle up to 1.2 bar of boost pressure. So far, it's been working fine; a friend of mine has a similar one in their car."
First engine/head/head gasket at 460,000 km, as long as you keep an eye on the oil temperature.
If you maintain it properly and don't drive it at full throttle all the time, it is quite durable.
More information on the topic: www.golf3TD.tk
@Golf2TD: All Mk2 models from a certain year onwards have a load-dependent start-up assist.
Mine too.
Hi, Jockel.
"Neu": Bora Variant, ASV
Back to top Profile PM Email
No new posts Differences ESP at AAZ: 028 130 107 R vs 028 130 107 K Diesel Engine Technology
No new posts ZMS Differences Upload
No new posts Unterschiede PDE 2.0 TDI Diesel Engine Technology
No new posts P-Box: Differences Explained Diesel Engine Technology
