Wiring Diagram, GRA, Skoda Octavia SLX, Manufactured 17.2.98
Octavia Fan
edgar05 likes this.
Post09-08-2004, 10:48    Subject: Wiring Diagram, GRA, Skoda Octavia SLX, Manufactured 17.2.98 Quote
Hello!
Does anyone have an electrical diagram for a Skoda Octavia SLX, built 17.2.98, engine 1U?
I have purchased a GRA and would like to install it, so far so good.
I also purchased the cable harness for the GRA.
Okay, now my questions:
1. Has my Skoda already pre-wired the cable harness for the GRA, so that I only have to install the remaining {COMPONENT}?
Do I need to install GRA levers?
2. If not, you need to connect all 4 cables to the control unit, which is located under the windshield wiper motor, as there are only 2 connected in the attached diagram.
Furthermore, the attached drawing is of the Passat 97 (I don't know if it's the same for the Octavia).
The cables are labeled as:
K.A.1
K.A.2
K.A.3
K.A.9
The cables should be plugged into the 10-way socket (T10k).
Can anyone tell me what function each cable is intended for?
Thank you in advance.
I hope you don't mind me bringing up the GRA topic again, but I
I was unable to find the answer that was suitable for me in the search function.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Octavia 1z 2.0 TDI BMM hat Leistungsverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1,9 On-Board Diagnostics (OBD)
No new posts Skoda Octavia BKC Warmstartprobleme Diesel Engine Technology
No new posts Skoda Octavia ABS Fault Transmission, Chassis, Body & Interior
No new posts Startprobleme Skoda Octavia On-Board Diagnostics (OBD)
