Clutch Not Disengaging? Get Help Now!
x world one
Post10-08-2004, 9:01    Subject: Clutch Not Disengaging? Get Help Now! Quote
Hello everyone,
My clutch is starting to annoy me a bit.
This manifests itself primarily by the clutch engaging very late. This means there's a very long "dead zone" before the clutch engages. Quick starts at a busy intersection, for example, are hardly possible unless you keep your foot on the clutch the entire time.
"Furthermore, sometimes when stopped at a traffic light, a rattling, grinding noise occurs as soon as the car comes to a halt, especially when the driver is not in gear and has not pressed the clutch pedal. This noise immediately disappears when the clutch pedal is pressed again and released."
During my vacation, I noticed that when overtaking, the 3rd gear seemed to get stuck when shifting, and then it smelled almost like burnt rubber after full acceleration. I sometimes experience a similar, but milder, smell when accelerating fully from a low speed in 5th gear, for example, starting around 80 km/h.
The usual test, engaging third gear and releasing the clutch, caused the engine to stall as expected.
I'm not sure exactly where to start looking. Could the clutch adjustment be stuck? Or is the clutch simply worn out?
Sure, no problem.
Henrik.
Spritmonitor
Translated on 03-09-2026, 9:37.
wolfi_b
Post10-08-2004, 14:00    Subject: Clutch Not Disengaging? Troubleshooting Guide. Quote
x world one wrote:
Clutch simulation possibly stuck?
Okay, my 1Z (though it's in an Audi 80) has a hydraulic clutch!
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 03-09-2026, 9:39.
x world one
Post10-08-2004, 14:06    Subject: Clutch Not Disengaging? Get Help Now! Quote
You're right, I agree.
But somehow, the clutch needs to be adjusted there as well.
Anyway, this problem is quite annoying in the long run, and a new coupling isn't exactly cheap.
Spritmonitor
Translated on 03-09-2026, 9:40.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 81KW - Kupplung rutscht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo SDI Clutch Problems: Not Disengaging? Diesel Engine Technology
No new posts Clutch Check: Is It Disengaging Properly? Diesel Engine Technology
No new posts Clutch Not Disengaging: Causes & Fixes Diesel Engine Technology
No new posts Kupplung trennt nicht mehr Diesel Engine Technology
