Opel LMM vs. VW: Vergleich & Unterschiede
dieterpapa
Post08-08-2004, 19:36    Subject: Opel LMM vs. VW: Vergleich & Unterschiede Quote
Hello specialists,
Today, I compared the mass airflow sensor (MAF sensor) from my Opel Sintra (2.2 DTI) with the one from a Ford Galaxy (130 hp PD).
Superficially (I haven't been able to fully examine them), the mass flow meters (specifically, just the fittings, not the entire tube) look very similar. The dimensions and mounting also appear identical. There are 5 connections present, but the coding on the connector looks slightly different.
Opel mass airflow sensors are expensive for the Sintra, but Volkswagen now offers very affordable alternatives (including, for example, the Pierburg mass airflow sensor from DC).
Is it possible to replace the mass airflow sensor (MAF) here? What are the differences between different MAF sensors?
Dieter.
Translated on 05-08-2026, 17:00.
joergs
Post09-08-2004, 12:01    Subject: Opel LMM vs. VW: Vergleich & Unterschiede Quote
According to a very knowledgeable Opel mechanic I know, there is no compatibility. Of course, it depends on trying it out...
But if there were a connection, someone would have definitely made money off of it by now.
Translated on 05-08-2026, 17:01.
Post11-08-2004, 15:23    Subject: Opel LMM vs. VW: Vergleich & Unterschiede Quote
Even the DC alternative isn't as relevant anymore.
LLMs cost Volkswagen just over €80 (when purchased as a replacement part).
Translated on 05-08-2026, 17:02.
joergs
Post11-08-2004, 15:44    Subject: Opel LMM vs. VW: Vergleich & Unterschiede Quote
Okay, I understand. Please provide the text you would like me to translate from German to English.
Performance loss, increased consumption, etc., can quickly turn the approximately €20 cost advantage into a losing proposition. Not to mention goodwill or warranty claims in case of problems...
Translated on 05-08-2026, 17:03.
dieterpapa
Post14-08-2004, 23:52    Subject: Opel LMM vs. VW: Vergleich & Unterschiede Quote
I can't imagine that VW would replace the Opel mass airflow sensor... icon_eek.gif so I'm going to go to 'Papa' Daimler and order one – as I said, it all depends on trying it out...
Unfortunately, I can't get the LMM (lambda manifold module) out of my Galaxy PD; it seems that they are no longer standard Torx screws with a hole, but some other type of nut again icon_twisted.gif.
Does anyone know the right tool for the job?
Dieter.
Translated on 05-08-2026, 17:04.
WarLord
Post17-08-2004, 20:38    Subject: Opel LMM vs. VW: Vergleich & Unterschiede Quote
Perhaps a multi-tooth key?
By the way: Does anyone know the part number of the current, improved mass airflow sensor (MAF) with separators for the 115 hp PD (ATJ) engine?
Best regards, WarLord.
Translated on 05-08-2026, 17:05.
joergs
Post17-08-2004, 21:58    Subject: Opel LMM vs. VW: Vergleich & Unterschiede Quote
Many people have struggled with using a Torx bit. It's a Torx bit with a hole in the middle.
'I actually found one that fits! It was more of a coincidence, though.'
Translated on 05-08-2026, 17:06.
dieterpapa
Post24-08-2004, 19:18    Subject: Opel LMM vs. VW: Vergleich & Unterschiede Quote
Dieter.
No new posts Opel: DTI 2.0 Diesel Engine Technology
No new posts VAG-COM for Opel? On-Board Diagnostics (OBD)
No new posts Opel 2.2 DTI: Cheap Parts? (Pre-2002) Diesel Engine Technology
No new posts Opel Astra 2008: Specs, Review & Price On-Board Diagnostics (OBD)
