VNT17 Turbo: Price & Specs
Go to page: 1, 2, 3  Next
dj1
Post22-07-2004, 9:27    Subject: VNT17 Turbo: Price & Specs Quote
I got a new turbocharger, specifically a VNT17 (GT1749VA from a VW Passat PD 130hp), for my Golf 3 (AFN).
Question:
- What boost level are you running on the turbo?
- How much horsepower does this turbo produce as standard?
- How much cash can this turbocharger handle continuously?
Thank you for your answers!
DJ.
Translated on 06-08-2026, 2:26.
SeatLeon
Post22-07-2004, 9:37    Subject: VNT17 Turbo: Price & Specs Quote
I don't have an answer, but I have another question.
I am running a boost pressure of 1.3 bar with the VNT-15, and experiencing overboosts up to 1.6 bar in the ALH. Is this still within the tolerance range of the turbocharger, or will there be problems in the short or long term?
Translated on 06-08-2026, 2:27.
Post22-07-2004, 10:03    Subject: VNT17 Turbo: Price & Specs Quote
SeatLeon wrote:
I am running a boost pressure of 1.3 bar with the VNT-15, and the overboost reaches up to 1.6 bar in the ALH
. Is this still within the tolerance range of the turbocharger, or will there be problems sooner or later?icon_eek.gif
I don't have a direct answer, but here's a hint:
The charging capacity is calculated by multiplying the volumetric flow rate by the pressure increase.
As the volumetric flow rate increases with boost pressure, the power output of the turbocharger increases almost quadratically with the boost pressure.
1.3 bar instead of 1 bar results in approximately 60% increased charging capacity under continuous operation.
1.6 bar -> approximately 2.5 times the turbocharger boost pressure for a short period }.
Although this is only somewhat comparable:
What would you say if an ALH engine, without any mechanical modifications, were tuned to produce a continuous power output of 90 horsepower and a short-term peak power output of 225 horsepower? Would there be problems in the long run?
Translated on 06-08-2026, 2:29.
eike
Post22-07-2004, 11:33    Subject: VNT17 Turbo: Price & Specs Quote
Hi there,
I'm assuming that the loader isn't being overloaded due to the torque on its shaft, but rather because of its excessively high rotational speed.
Does anyone have any ideas on how to measure this? Could it possibly be done through acoustic measurement? At low speeds, you can hear the turbocharger whistling. When it starts producing boost, the frequency likely increases into inaudible ranges, which might still be measurable and analyzable using a microphone (piezoelectric sensor).
Perhaps it would be possible to build an analog multiplier that multiplies the engine speed by the boost pressure, thereby estimating the turbocharger speed and displaying it on a gauge. It seems unlikely that it would be feasible to tap into the turbocharger shaft itself and measure its speed...
Then it would be possible to design a tachometer with a 'redline' specifically for a turbocharged engine.
For a boost pressure of 1.3 bar, you need less turbocharger speed at 2000 RPM than at 3800 RPM, which means you can optimize the turbo's performance across all engine speeds.
Does anyone have any ideas on how to implement a tachometer for a turbocharger?
Greetings.
Eike.
Translated on 06-08-2026, 2:32.
dj1
Post22-07-2004, 14:03    Subject: VNT17 Turbo: Price & Specs Quote
Is anyone not using the turbo?
Hello?
Translated on 06-08-2026, 2:34.
Post22-07-2004, 14:39    Subject: VNT17 Turbo: Price & Specs Quote
eike wrote:
For a charging pressure of 1.3 bar, you need less turbocharger speed at 2000 RPM than at 3800 RPM, which means you can optimally utilize the turbocharger in every speed range.
That's probably less true than you might initially think.
In simplified terms, the characteristic curves of a blower indicate that while the blower speed always increases with the required pressure, it is almost independent of the mass flow rate within a large operating range.
In other words: 1 bar of boost at 2000 engine RPM means nearly the same turbocharger speed as 1 bar of boost at 4000 engine RPM, provided that the turbocharger is well-matched to the engine.
-> The lower the gas flow rate, the more the turbocharger "spins out of control" (figuratively speaking), and the lower its efficiency becomes.
Please search for information about charging curves and related topics here.
You'll find corresponding images somewhere that will help you understand.
Translated on 06-08-2026, 2:36.
dennis79
Post23-07-2004, 16:41    Subject: VNT17 Turbo: Price & Specs Quote
Der GT1749VA wird in nahezu jedem 130PS PD Motor verbaut. You only need to.
Make sure it doesn't have a pre-attached manifold. (1.3 bar standard pressure).
1.5 bar is easily achievable icon_twisted.gif.
I drive one myself in my AFN icon_biggrin.gif.
Dennis.
Translated on 06-08-2026, 2:38.
dj1
Post23-07-2004, 17:57    Subject: VNT17 Turbo: Price & Specs Quote
Dennis
Hi Dennis,
'Mine doesn't have a manifold!'
I'm going to install it tomorrow.
Can you tell me a little more about your renovation?
Where did you have your engine tuned?
How long have you been driving the Turbo?
Satisfied?
'Etc...'
DJ.
Translated on 06-08-2026, 2:39.
dr_braun
Post23-07-2004, 19:21    Subject: VNT17 Turbo: Price & Specs Quote
@DJ1:
'Could you possibly take some pictures during the conversion? That would be great because I'm planning to do something similar soon. As far as I know, the oil lines should fit, but the intake hose will need to be modified. Does the compressor fitting connect to the AFN pressure pipes?'
Best regards, Sebastian.
Translated on 06-08-2026, 2:41.
Post24-07-2004, 16:47    Subject: VNT17 Turbo: Price & Specs Quote
dr_braun wrote:
@DJ1:
..could you possibly take some pictures during the conversion? That would be great because I want to do it soon too. The oil lines should fit, but as far as I know, the intake hose needs to be modified. Does the connection of the supercharger fit the AFN pressure pipes?
Okay - everything matches perfectly 1:1, except the compressor output, which has a clip connector. icon_smile.gif
Solution: Take the connection adapter for the charge pressure hose from this shop here.
Translated on 06-08-2026, 2:43.
dennis79
Post24-07-2004, 17:42    Subject: VNT17 Turbo: Price & Specs Quote
Hello Dj1,
I drove the VNT17 for a while with 1.4 bar -- I didn't have any problems with it icon_biggrin.gif.
How much boost pressure do you want to run icon_question.gif?
The pressure build-up takes longer in the lower RPM range, but you experience almost no turbo lag (overshoot). This is because the larger turbocharger has a bigger compressor housing – the AFN engine uses the smaller one.
I've temporarily removed the chip because I installed nozzles with a size of 0.216.
I did not personally carry out the renovation icon_redface.gif.
Keep us updated.
Translated on 06-08-2026, 2:45.
dj1
Post24-07-2004, 19:43    Subject: VNT17 Turbo: Price & Specs Quote
Hello Dennis79,
Thank you for your reply!
I once read that you don't necessarily need extremely high boost pressure to achieve good performance.
I think around 1.3 bar of boost pressure should be sufficient for 150-160 horsepower.
I also have the large nozzles installed icon_cool.gif.
Once the turbo is installed, I'll definitely need to do some tuning.
DJ.
P.S.: How long have you had the turbo installed?
Translated on 06-08-2026, 2:47.
Garret
Post25-07-2004, 10:29    Subject: VNT17 Turbo: Price & Specs Quote
Here's an installation guide for the VNT 17 turbocharger into an AFN engine (Passat).
from the Manuel A4 TDI manual.
Installation instructions
Perhaps this will help.
Translated on 06-08-2026, 2:48.
dennis79
Post25-07-2004, 14:50    Subject: VNT17 Turbo: Price & Specs Quote
Hello dj1,
What kind of car do you drive, and what is your fuel efficiency (miles per gallon)?
What boost pressure are you running right now, and is your clutch slipping?
Did yours have the standard software and the 0.216 nozzles installed? (Mine has a little bit of stringing, but not much – I can't shake the suspicion that there might be a slight leak in my pressure hose).
Translated on 06-08-2026, 2:49.
dj1
Post25-07-2004, 18:15    Subject: VNT17 Turbo: Price & Specs Quote
Hi Dennis,
It's all in the first post!
Boost pressure is 1.0 bar.
With the larger nozzles, there's a little more soot, but it's really minimal!
Translated on 06-08-2026, 2:50.
dennis79
Post27-07-2004, 16:30    Subject: VNT17 Turbo: Price & Specs Quote
Do you already have the turbo installed icon_question.gif?
Translated on 06-08-2026, 2:51.
No new posts VTG Rod Adjustment: VNT17 Installation Guide Diesel Engine Technology
No new posts Which charging cable or adapter for VNT17? Diesel Engine Technology
No new posts VNT15 vs. VNT17: Which Turbo Fits? Diesel Engine Technology
No new posts Abgastemperatursensor GT1749VA On-Board Diagnostics (OBD)
