Audi A8 documentary: Creaking/grinding noises in the sunroof area (Solution)
Michael II
Post30-08-2004, 10:00    Subject: Audi A8 documentary: Creaking/grinding noises in the sunroof area Quote
Creaking or groaning noises coming from the sunroof area, primarily when driving on rough roads. The noise mainly occurs at high or low outside temperatures combined with low humidity.
Up to vehicle number: 8E 3N 260 999.
Cause:
Ripping or tearing noises between the sunroof seal and the roof opening due to relative movements.
Solution:
If you hear a noise, bring the sunroof to its open position. After that, the noise should no longer be present or should only be very faint.
This distinction is important because the cause of the noise is often mistakenly attributed to the roof lining.
Clean the sunroof seal and the roof opening with an alcohol-based liquid (e.g., glass cleaner). Then, apply a suitable lubricant (e.g., a small sponge) to the seal using the special lubricant No. G 060 172 A3.
Tschüss
Michael II
Translated on 14-07-2026, 15:41.
Ratings - Audi A8 documentary: Creaking/grinding noises in the sunroof area
No new posts Audi A3 Seat Creaking: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Sunroof Rattle Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentation up to 05/99, sunroof stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sunroof Noises: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Steering Noise: Causes & How to Fix It Transmission, Chassis, Body & Interior
No new posts Sunroof Calibration: Basic Settings Transmission, Chassis, Body & Interior
No new posts Fine-tuning electrical devices. Sunroof in the A3 Transmission, Chassis, Body & Interior
