Passat 3B: Excessive Smoke Under Load - Troubleshooting
tonruf
Post25-09-2004, 8:53    Subject: Passat 3B: Excessive Smoke Under Load - Troubleshooting Quote
Hello fellow diesel mechanics and experts, my Passat TDI is giving me a lot of trouble:
'At 2000 RPM, there's a noticeable drop in power with excessive smoke. At 3000 RPM, the problem disappears, and it doesn't smoke as much then. Oil consumption is not significant/minimal. No oil has been added since the last oil change 15,000 km ago. I also do NOT use biodiesel. Otherwise, it makes no unusual noises. It starts perfectly fine, with no issues. The mass airflow sensor (MAF) was replaced about 30,000 km ago and should ideally last at least that long again, because I need the car for my self-employment! Looking forward to your help. Thanks and regards, Lorenz.'
Translated on 05-08-2026, 17:07.
No new posts Airtronic D2 Defective: Troubleshooting Smoke Issues General Tips
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Worn clutch disc pressure plate bearing, Golf/Bora 85KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 2.5 TDI BDH 180 hp smokes under load and at idle Diesel Engine Technology
No new posts Passat PD, manufactured in 1999 (85kW, approx. 85,000 km)... Diesel Engine Technology
No new posts Passat Smoking: Troubleshooting & Repair Guide Upload
No new posts Passat PD: Performance Issues & Power Loss Diesel Engine Technology
