Used ATL 35i Passat, engine 1Z
UlrichLange
Post13-09-2004, 20:05    Subject: Used ATL 35i Passat, engine 1Z Quote
Does the engine need to be lifted or lowered for an automatic transmission (AT) replacement on a Passat 35i with the 90 hp engine (MKB: 1Z), or is there enough space to remove the turbocharger from above?
Thank you for the information.
Ulli.
Translated on 15-07-2026, 18:43.
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Passat 3B ZR Replacement Diesel Engine Technology
No new posts Passat Diesel Filter Replacement Diesel Engine Technology
No new posts No power after timing belt/chain replacement / Passat TDI... Diesel Engine Technology
No new posts Passat 1.8T: Loud Engine Noise? Causes & Fixes Diesel Engine Technology
