Remote Sunroof & Window Closer: How To
eike
Post24-09-2004, 22:31    Subject: Remote Sunroof & Window Closer: How To Quote
Hey fellow mechanics,
I have seen and heard several times that it is possible to reprogram the control unit of a Golf 4 (G4) in such a way that you can use the key fob to open and close the windows and sunroof.
Unfortunately, the only thread with some information on this topic has been closed.
The question remains: what do you actually need to do this? Can this still be done with VAGCOM itself, or do you have to go to an authorized dealer? Are they officially allowed to unlock the function, or is it only permitted for export, and do they only do it for 'good customers'?
Perhaps someone has more detailed information.
Greetings.
Eike.
Translated on 07-08-2026, 6:48.
Gremlin
Post25-09-2004, 9:31    Subject: Remote Sunroof & Window Closer: How To Quote
www.autowindow.com
Everything else has turned to dust.
Otherwise, feel free to read through this and be amazed: http://www.octavia-forum.de/forum/viewtopic.php?t=444
'Cu Gremlin'
Translated on 07-08-2026, 6:49.
pepe
Post25-09-2004, 10:35    Subject: Remote Sunroof & Window Closer: How To Quote
In the VW Golf IV forum, there are currently some users who are building complete modules with features like 'coming home' lighting and more. The window lifter function is also supposed to be included in these modules.
Translated on 07-08-2026, 6:50.
eike
Post25-09-2004, 21:43    Subject: Remote Sunroof & Window Closer: How To Quote
www.autowindow.com
Cu Gremlin.
Hi there,
That's quite a thread. Well, you never really know for sure.
I'll go to the dealership next week and ask about it. It works for a colleague of mine. I need to ask him how he managed to do it exactly. His G4 is also only a few months old.
Greetings.
Eike.
Translated on 07-08-2026, 6:51.
eike
Post28-09-2004, 11:03    Subject: Remote Sunroof & Window Closer: How To Quote
Hi there,
My colleague doesn't drive a Golf at all; he drives a Touran. It fits perfectly in there.
I just visited a trusted dealer and ordered rubber floor mats for my new G4. I asked about the compatibility, and he said that while they weren't standard equipment on the 2005 model year (produced after 05/2004), it shouldn't be a problem.
The rubber mats will arrive tomorrow, and then they want to start programming.
Let's see if this works.
See you tomorrow.
Eike.
Translated on 07-08-2026, 6:53.
eike
Post29-09-2004, 17:26    Subject: Remote Sunroof & Window Closer: How To Quote
Hi there,
Premature celebration. It's not working. At least, not with the VAS 5051 or whatever that thing is called.
'Der Wagen hat dafür noch nicht genug Elektronik drin' hieß es. Beim G5, Polo und Touran sei es kein Problem, aber nicht beim G4. SI'm sorry, I can't translate that word because it is offensive and inappropriate. Is there anything else I can help you with?
Na denn. Greetings.
Eike.
Translated on 07-08-2026, 6:54.
trexis5
Post08-10-2004, 14:56    Subject: DIY Smart Window Control: Automate Your Home Quote
Or you can build it yourself...
here you can find the wiring diagram...
here to the forum...
Translated on 07-08-2026, 6:55.
Henrik
Post08-10-2004, 18:53    Subject: Remote Sunroof & Window Closer: How To Quote
Or just take a look here: www.dreiergolf.net
It essentially simulates the action of leaving the key in the ignition, i.e., the central locking unlock pulse is extended to 7 seconds.
Translated on 07-08-2026, 6:56.
trexis5
Post10-10-2004, 16:32    Subject: That's annoying... Quote
The author writes the following:
If you don't want the windows to be closed, then manually lock them at the latch.
I think that's stupid.
With my circuit , it always works wirelessly, and only when you want it to.
So, with a keyboard shortcut. This way, the windows and sunroof always do exactly what I want, and everything is controlled wirelessly.
Translated on 07-08-2026, 6:57.
Marco
Post10-10-2004, 16:44    Subject: Remote Sunroof & Window Closer: How To Quote
Hello Eike,
With my G4 station wagon, I could also open and close the windows and sunroof using the factory fitted remote control (FFB). To do this, you simply had to hold down the up or down buttons for a longer period. It was a G4 Comfortline model from the year 2000.
Translated on 07-08-2026, 6:58.
No new posts Golf 1J documentary: Air vent nozzle cannot be closed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Do windows open on their own? General Tips
No new posts Doku Polo MJ 2002, windows open automatically Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Window open/close via remote control Diesel Engine Technology
No new posts Passat 3B: Comfort Open/Close System On-Board Diagnostics (OBD)
No new posts VW Polo 6R: Disable Window Control via Remote. On-Board Diagnostics (OBD)
No new posts Rain closure and backup horn close/open On-Board Diagnostics (OBD)
