TDI Turbo Upgrade: Passat 1.9, 86kW ATJ
knarf
Post20-11-2004, 20:28    Subject: TDI Turbo Upgrade: Passat 1.9, 86kW ATJ Quote
Hello, I heard that the turbocharger from a 130hp Passat PD engine (engine code AVF and AWX) can be fitted to a 115hp engine (engine code ATJ). Is that true? They say only minor modifications are needed.
Does anyone know which one?
I think there are probably different turbocharger versions available for the ATJ engine. I have the turbocharger with part number 028145702h installed.
Translated on 05-10-2026, 9:07.
joergs
Post20-11-2004, 23:16    Subject: TDI Turbo Upgrade: Passat 1.9, 86kW ATJ Quote
'The one with 130 hp uses a VNT17 turbocharger. The one you have installed is probably a VNT15. It will definitely work somehow. In my opinion, you'll need quite a few other parts for the intake system, and possibly a different oil line to the turbocharger.'
Translated on 05-10-2026, 9:08.
Post21-11-2004, 11:44    Subject: TDI Turbo Upgrade: Passat 1.9, 86kW ATJ Quote
Make sure to check what type of turbocharger you have on the 115 hp engine, as it's possible that it's the same one used on the engines you mentioned.
Translated on 05-10-2026, 9:09.
WarLord
Post21-11-2004, 15:23    Subject: TDI Turbo Upgrade: Passat 1.9, 86kW ATJ Quote
AFAIK, the AJM and ATJ models have already received the VNT17 upgrade.
Best regards, WarLord.
Post21-11-2004, 18:54    Subject: TDI Turbo Upgrade: Passat 1.9, 86kW ATJ Quote
Okay, aside from that, what do you even need a loader that's 8 (or possibly more) sizes larger for? What other changes are you planning to make?
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
No new posts Passat PD ATJ: Engine Performance Issues Diesel Engine Technology
