Jan03 Blaumann
Joined: 08/24/2003 Posts: 142 Karma: +6 / -0 Location: Dänemark 2010 Volkswagen Polo Free account, no CAN development support
06-10-2004, 11:27 Subject: ESP from AFN to 1Z? |
Hello
Just to make it clear, I'm not talking about any kind of modification. If you look around, there are quite a few ESPs (presumably referring to specific equipment) from AFN available for purchase, and as far as I understand, AFN hasn't had any issues with pump malfunctions.
After I've replaced everything else on my 1Z (GDV's, nozzles, hydro's), and the engine still has a strong knocking sound (only under load), I'm going to try replacing the fuel pump.
Can I simply screw the AFN pump into my 1Z and assume that my control unit will work with it?
Has anyone done this before?
/Jan
1994, Golf III, 1Z
Profile PM Garage |
WarLord Guest
06-10-2004, 20:50 Subject: ESP from AFN to 1Z? |
The AFN has a different engine computer. There was a discussion on the board about whether the rattling could be caused by the engine computer. In the end, I actually think it could be, since we had a 1996 Passat with 174,000 km that didn't rattle at all (first fuel pump and first set of injectors, including the needle valve).
But unfortunately, I don't have an answer to your actual question.
Best regards, WarLord
Sternengucker80 Guest
07-10-2004, 1:14 Subject: ESP from AFN to 1Z? |
Hi!
The AFN pump is the same as the 1Z! You just need to pay attention to the connector!!!! There are pumps with round and oval connectors! I think they also have a different number of poles, 8 and 10-pole!? You just need to compare them! Is it dependent on the year of manufacture? From pressure, pump pistons, flow rate, etc. – everything is the same!
Best regards, Timo
