Octavia side airbag crash sensors, short circuit
Sven_29
Post09-10-2004, 13:13    Subject: Octavia side airbag crash sensors, short circuit Quote
The airbag warning light is illuminated on my Skoda Octavia. The diagnostic scan indicates a short circuit to the positive terminal on the right-side airbag crash sensor.
Where are the crash sensors located?
What problem might be present here?
Sven.
Julian
Post09-10-2004, 13:22    Subject: Octavia side airbag crash sensors, short circuit Quote
It can be either on the airbag unit or centrally on the transmission.
Most often, the connector under the seat is damaged and should (the wiring harness) be replaced. It's quite affordable.
mummelratz
Post14-10-2004, 20:51    Subject: Octavia side airbag crash sensors, short circuit Quote
No, there is no sensor on the transmission that has anything to do with the airbag system. Similarly, there is no sensor on the airbag units themselves.
The crash sensor for the left-side airbag is located in the driver's footwell, in front of the seat. Please remove the door sill trim and lift up the carpet. You will see a black metal plate that is screwed to the reinforcement of the underbody. You need to unscrew that, because the side airbag crash sensor is located there.
Furthermore, the airbag control unit also contains a crash sensor for the front airbags and a safety sensor.
Sven_29
Post14-10-2004, 21:55    Subject: side airbag again Quote
Thank you for your responses.
Does the sensor in the footwell control both side airbags, or is there a separate sensor for each airbag?
Thank you very much.
mummelratz
Post15-10-2004, 23:32    Subject: Octavia side airbag crash sensors, short circuit Quote
Of course, there's a crash sensor on every side.
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Side Airbag A6 2.4, 1999 Diesel Engine Technology
No new posts Side Airbag Malfunction: Loose Connection? Diesel Engine Technology
No new posts A4 Bj7/96: Kurzschluß am Blinker-Relais ? Diesel Engine Technology
No new posts A3 Problem Side Airbag Connector Transmission, Chassis, Body & Interior
