AHU Start-up Value: Find out the initial value.
tannen
Post28-09-2004, 10:16    Subject: AHU Start-up Value: Find out the initial value. Quote
Hello.
I need the boost start setting value for the ESP of the 90hp AHU-TDI engine (which is equipped with EDC).
I can't adjust the timing with VCDS because the engine won't start, and I suspect the ESP (Electronic Stability Program) is completely misaligned. The KW (clockwise) and NW (counter-clockwise) marks are aligned with the timing marks. I want to adjust it now using a dial indicator, as was done with older diesel engines that didn't have diagnostic capabilities.
Does anyone know the value of this engine?
I hope someone can help me.
Translated on 17-10-2026, 8:40.
Post28-09-2004, 10:19    Subject: AHU Start-up Value: Find out the initial value. Quote
Hi.
I'm afraid I don't know the value, but if you find anything about the 1Z, you can use that information.
The two engines are virtually identical - in fact, they are completely the same when it comes to the injection system.
Translated on 17-10-2026, 8:41.
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Start of AEL funding - Early value maximization? Diesel Engine Technology
No new posts LMM Value Too High? Troubleshooting Guide. On-Board Diagnostics (OBD)
No new posts Engine mass at idle, VAG-COM value Upload
No new posts AHF Tdi. Value of the initial injection start? On-Board Diagnostics (OBD)
