Oh dear...
The confusion is truly perfect.
But as I see, you probably know a lot about that
Yes... so, about leaks... how can I check for them?
I sprayed the entire engine compartment with leak detection spray.
And as a result, he couldn't find anything conclusive. I had only suspected it myself.
to see if air is whistling through the nozzles.
So, the strange thing about it is that if the fuel *really* flows back...
If it should happen, then it only occurs when the device is in a warm state.
Und das leuchtet mir irgendwie nicht ein. BECAUSE.
When the engine is warm, if I turn it off and then start it again after 10 minutes...
It's best to keep trying, but it might take some time for him to respond.
If I leave it like that until, for example, tomorrow morning, it will start up immediately.
Ah yes... the compression was measured when the engine was cold, I think.
I should measure that again when it's warm.
And that thing about the injection timing, so as I said, supposedly...
checked, and as far as I can tell, everything was fine, so they didn't have to do anything.
But I'm not entirely sure about that myself, because of the central screw on the pump.
"It was just as dirty as I had left it. Therefore..."
That's not quite Kosher. Or how do you spell that?
I'll go over everything again this weekend, if anyone...
If you have any other ideas, that would be great. I'm not sure how to proceed from here.
Regards, Acid.
