Print Test: How to & Video Guide
A2TDI
Post27-08-2004, 14:17    Subject: Print Test: How to & Video Guide Quote
Today, I did a pressure test because I suspected that the boost pressure was dropping.
I connected my pressure test adapter directly to a pressure hose after installing the turbo. However, I noticed that the pressure is escaping quite quickly.
http://www.leibbrands.de/Drucktest.MOV (approximately 8MB)
Is it normal for the pressure to drop so quickly?
It used to work better somehow. Or am I just imagining that? icon_confused.gif
- Measured absolute boost pressure: 2200 mbar -> OK.
- LMM (likely meaning 'low molecular mass') approximately 2 months old, and values are within normal limits.
- AGR valve cleaned 8000 km ago.
- Air filter replaced 8000 km ago.
Vehicle: A2 1.4 TDI AMF, chipped, 75,000 km.
Thomas.
Translated on 30-10-2026, 6:42.
klopfer
2007 Audi A4 Avant
Post12-09-2004, 18:17    Subject: Print Test: How to & Video Guide Quote
Hello Thomas,
"This might not be helpful right now, but what kind of pressure test adapter do you have?"
Thomas.
Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
Translated on 30-10-2026, 6:44.
A2TDI
Post26-09-2004, 14:27    Subject: Print Test: How to & Video Guide Quote
I built it myself. It's a plastic tube that fits perfectly inside the hose. A car valve is glued to the front end.
The pipe is inserted into the hose and secured with a clamp. Then you can apply pressure with the compressor.
Thomas.
Translated on 30-10-2026, 6:45.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post26-09-2004, 15:42    Subject: Print Test: How to & Video Guide Quote
And where exactly did you close off the intercooler piping?
on the intake manifold?
B.Eng (FH) u. KFZ Meister
No new posts Video 320d Upload
No new posts ASZ No Start: Troubleshooting & Repair (Video) Diesel Engine Technology
No new posts ASR Issue: Audi 8D/B5 Questions On-Board Diagnostics (OBD)
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
