MickS wrote: |
With my Golf IV TDI, manufactured in 1998, I have the problem that it starts very well when cold, but when warm, it only starts after a long cranking.
The problem occurs quite frequently, as I have also read here. |
And that's why there's also a technical article about starting problems, and your symptoms are addressed in it.
Tip: Don't necessarily believe everything the workshop tells you (and especially not that everything was done correctly)
