Steering Gear Assembly: How to Build It
wolfi_b
Post07-10-2004, 6:46    Subject: Steering Gear Assembly: How to Build It Quote
Hello.
Does anyone know how the steering system is constructed in my vehicle?
Background: Two weeks ago, I replaced the clutch and had to remove the tie rods from the steering rack. On this vehicle, both tie rods connect to a U-shaped piece that is then screwed onto the right end of the steering rack, and it was this connection that I loosened. I also moved the steering and the wheels to remove the gearbox.
After the action, the steering wheel was misaligned, and the alignment test showed a 26mm misalignment.
Could it be that the repeated turning of the steering wheel has caused the steering rack to rotate a few times, and therefore shift in one direction? Or is that not possible? I seem to remember that the steering rack where the tie rod ends are attached was twisted.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 01-09-2026, 20:18.
LZ
Post07-10-2004, 10:55    Subject: Steering Gear Assembly: How to Build It Quote
"The inner tie rod ends? In any case, the rack and pinion gear cannot twist. Wouldn't it have been simpler to loosen the cone on the hub and pivot the entire assembly?"
Best regards, Robert.
Translated on 01-09-2026, 20:20.
wolfi_b
Post07-10-2004, 11:51    Subject: Steering Gear Assembly: How to Build It Quote
LZ wrote:
the inner tie rod ends??
Inside, there are no actual tie rod ends. The tie rods only have a hole with a rubber bushing, through which they are screwed to the U-shaped part mentioned above. Nothing can twist or rotate there.
LZ wrote:
In any case, the toothed wheel cannot twist.
Are you sure about that? I think something might be wrong.
LZ wrote:
Wouldn't it have been easier to loosen the cone on the axle stub and pivot the entire assembly?
No, because that U-shaped part and the tie rods were in the way.
Note: The engine and transmission are mounted longitudinally.
1993 Audi 80 B4 1Z
Translated on 01-09-2026, 20:21.
LZ
Post07-10-2004, 17:55    Subject: Steering Gear Assembly: How to Build It Quote
Hello.
I'm not as familiar with single-sided gears anymore, but could it be that there are 2 holes in the carrier and 3 in the toothed rack? That would most likely explain the misalignment. And the toothed rack can't be twisted, otherwise the worm gear would have to compensate, which would be an undesirable situation!
Translated on 01-09-2026, 20:22.
wolfi_b
Post08-10-2004, 6:17    Subject: Steering Gear Assembly: How to Build It Quote
LZ wrote:
I don't have the details of the single-sided gears so clearly in my mind now, but could it be that there are 2 holes in the carrier
and 3 in the toothed rod icon_eek.gif?
I've also considered that, but the toothed rod and the support close flushly. I don't think that's the case.
I have no idea what happened there }.
To get back to my question: How is the steering system constructed?
Does the toothed rack have teeth on the top side and is it driven by a gear? However, the steering linkage enters the steering gear centrally, so that can't be the case.
How does the re-enactment work?
1993 Audi 80 B4 1Z
Translated on 01-09-2026, 20:23.
No new posts **Hydrostößel: Construction and Function** **Construct... Technical Articles
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Installation: A Complete Guide Transmission, Chassis, Body & Interior
No new posts Gas Removal for Soil Improvement Upload
No new posts Blinker Switch: Mechanical Design and Disassembly Diesel Engine Technology
No new posts Steering Gear: Types, Function & Maintenance On-Board Diagnostics (OBD)
