Wonderful... then I'll give it a try.
'I'll start by soldering in the socket pins (if they haven't already been installed, which I assume isn't the case).'
not going out...?!)
and then, if necessary, I can always still 'back out'
Thank you for the quick help!
P.S. I have just 'fully and specifically' determined that the last letters definitely differ: GIII: ...021JG; A4: ...021GN.
What is your estimated probability that it will work?
not ?? If there's virtually no chance, I will definitely not do it from the beginning, because it's not worth the effort for me.
