TDI Graph Settings: Optimize Your Results
MichaelJ
Post01-10-2004, 20:26    Subject: TDI Graph Settings: Optimize Your Results Quote
If I want to adjust the injection timing using the TDI graph, the program offers me...
Four different 1Z options to choose from:
80 1Z 92-2.94
80 1Z >2.94 (>ver.D08)
80 1Z >2.94 (rev. D09)
All 1Z 1994>
92-2.94 - bedeutet für mich von 1992 bis Februar 1994. But what does it mean?
Does that mean each time until February 1994, with different software versions of the ECU icon_question.gif?
And why are these listed, if the setting 80 1Z 92-2.94 covers this period icon_question.gif?
Does "All 1Z" then apply to all 1Z models from February 1994 icon_question.gif?
I'm a little confused icon_confused.gif. I have my 1Z, manufactured in 4/94, configured with the setting "All 1Z," but I would like to know if that's correct.
Okay, ich werde den Text übersetzen und dir dann eine Erklärung geben. Bitte gib mir den deutschen Text.
MichaelJ
Audi 80 TDI , MKB: 1Z, KM >455.000 r.i.p.
Passat 3B TDI, MKB: AJM, KM >331.000 r.i.p.
Audi A4 Cabrio Quadro, MKB: ASB KM> 119.000 -ZKD defekt, 6 Zylinder voller Riefen ATM 16tsd €! ATM 2 Tage vor Garantieende getauscht, da drei defekte Injektoren zwei Jahre lang nicht getauscht wurden.
Translated on 22-10-2026, 2:42.
Kristian
Post02-10-2004, 10:50    Subject: TDI Graph Settings: Optimize Your Results Quote
hello,
>2.94 (>ver.D08) or >2.94 (ver.D09) simply indicates different STG (Steuergerät - control unit) versions. This should be visible when accessing the STG with VAG-Com (the identification/designation of the STG is displayed in the window if it is recognized).
While I'm not 100% familiar with the 1Z engine, I've also observed similar differences in my AEL engine. When adjusting the injection timing, there's a distinction made based on the "TDI graph" and the engine speed (1000 rpm or 1200 rpm), and this depends on the software version of the engine control unit.
I have two almost identical ECUs (Engine Control Units), but with different software versions. I was initially puzzled as to why the engine suddenly only ran at 1000 RPM during adjustment after replacing the ECU.
To be sure which one belongs to you, you would either need to inquire with the "friendly" staff, consult the original Audi repair manual, or list your ECU (Engine Control Unit) identification number here so that someone can provide you with information.
Best regards, Kristian.
96´er A6 Avant 2,5 TDI 140@170PS AEL-Motor
zZ Probleme wenig Leistung+hoher Verbrauch trotz aller neu eingebauten Teile => ca 11T€+5T€ für neuen motor+ neues getriebe 1,5T€ = 17,5T€
Translated on 22-10-2026, 2:45.
Hati
Post02-10-2004, 12:22    Subject: TDI Graph Settings: Optimize Your Results Quote
@MichaelJ
If your FGST number is greater than 8CR150000, then you have it correct. Before this FGST number, you would have had software version D09. The D09 version was already in use at the end of 1992/beginning of 1993. Only the very first 1Z models in the 80 TDI had the D08 version, and that was until the middle/end of 1992.
Your engine control unit should have the part number 028 906 021 ET.
Translated on 22-10-2026, 2:47.
HugoHiasl
Post04-10-2004, 15:46    Subject: TDI Graph Settings: Optimize Your Results Quote
I also have a question about that.
I also wanted to check the injection timing on my Golf III TDI 90PS 1Z, manufactured in March 1996.
So, I've now connected the VAGCOM twice, borrowed from a friend, and tried to access measurement block group 000. But it automatically switches to group 001 and displays that instead.
'Does this group 000 not exist for all 1Z engines? The engine control unit is 028 906 021 BF. I'm somehow at a loss. I would have had it done at the workshop, but I can't really plan long-term, and they want you to register two weeks in advance.'
His VagCom version was 303.1, as far as I remember. At least, the TDIGraph program was in the directory. I didn't see the button for it, because I can't activate group 000, and therefore I can't click the button to return to the basic settings.
Can someone tell me what I'm doing wrong?
Thank you very much.
Oliver.
Translated on 22-10-2026, 2:49.
Hati
Post04-10-2004, 16:35    Subject: TDI Graph Settings: Optimize Your Results Quote
It's highly likely that this wasn't a full version of VAG-COM.
Then that group 000 doesn't exist.
Translated on 22-10-2026, 2:51.
Theresias
Post04-10-2004, 20:27    Subject: TDI Graph Settings: Optimize Your Results Quote
His VagCom version was 303.1, as far as I can remember. At least, the program TDIGraph was in the directory. I didn't see the button for it, because I can't activate group 000, and therefore I can't click the button to return to the basic settings.
He should really update to the latest version, 311.2.
For users who have properly registered, this is free of charge, and all measurement groups and other functions are included.
HugoHiasl
Post05-10-2004, 11:08    Subject: TDI Graph Settings: Optimize Your Results Quote
Thank you for the information.
He seems to be using the unregistered version, as he probably only uses it once a year to read the error codes.
I just ordered the full version.
Oliver.
Translated on 22-10-2026, 2:52.
No new posts VCDS: Adjusting Glow Plug Timer on VAG TDIs Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Graph and AKN? Diesel Engine Technology
No new posts TDI Engine Light: Causes & Fixes Diesel Engine Technology
No new posts AFN not in TDI graph On-Board Diagnostics (OBD)
No new posts TDI Graph: Analyze & Optimize Engine Timing On-Board Diagnostics (OBD)
