Tribune.Inc Guest
07-10-2004, 19:38 Subject: Tachometer Lighting: Improve Visibility & Safety |
Hello everyone,
Today, I removed the speedometer from my Audi 80 B4 TDI, manufactured in 1993, to replace the illumination bulbs because the lighting on the right side was no longer working properly. I took two bulbs from an old speedometer that I had at home and replaced the faulty ones.
'At the same time, I also unscrewed the circuit board to take a closer look at it! I then carefully reassembled everything and installed it in my car! When I reconnected the battery and tried to test the lighting, I barely saw anything because almost all the lights were out! It was also difficult to see the outside temperature display! I had the ignition on and my radio playing, when suddenly my mini-check beeped and indicated that the battery voltage was too low!'
My question now is, could it be that the battery is the reason the lighting isn't working (even with the engine running), or did I overlook something during the assembly?! All the connectors are properly inserted, and otherwise everything seemed to be fine!!
I tried using the search function, but unfortunately, I couldn't find anything.
'Thank you in advance!'
Michael.
Translated on 25-10-2026, 18:50.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
07-10-2004, 20:32 Subject: Tachometer Lights: Installation & Troubleshooting |
Tribune.Inc wrote: | | My question now is, could it be that the lighting not working (even with the engine running) is due to the battery? |
No, that can't be right. As soon as the engine starts, you should have a sufficiently high battery voltage. You probably didn't get it 100% correct when assembling it or connecting the plug...
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 25-10-2026, 18:52.
Profile PM Garage |
Tribune.Inc Guest
08-10-2004, 15:16 Subject: Tachometer Lighting: Improve Visibility & Safety |
It's been resolved... the problem more or less solved itself...!!
I looked at everything again, reassembled it, and yes, it worked again!
Michael.
Translated on 25-10-2026, 18:53.
08-10-2004, 16:26 Subject: Tachometer Lighting: Improve Visibility & Safety |
Tribune.Inc wrote: | | I looked at everything again, then reassembled it, and yes, it worked again! |
... and as so often happens, no one knows where the bug was hiding. Gruß Ulf
Profile PM Garage |
Tribune.Inc Guest
09-10-2004, 11:49 Subject: Tachometer Lighting: Improve Visibility & Safety |
I re-examined everything, took it apart again, and then put it back together, and yes, it worked again!
... and as so often happens, no one knows where the bug was hiding ?
It might have just been a brief contact... but I'm glad everything is okay now!
Michael.
Translated on 25-10-2026, 18:54.
mahk Blaumann
Joined: 08/12/2004 Posts: 121 Karma: +1 / -0 Location: München
11-10-2004, 7:21 Subject: Faulty Odometer: Troubleshooting & Repair |
Here's what comes to mind: Is it very complicated to disassemble all of this? And can you then access the total and daily mileage counters from the back? Mine tend to get stuck, and they only start working again after I've fiddled with the reset button, whereas the speedometer needle continues to function  . Typ89 SB: 05/2000 120.000km - 01/2005 295.000km (unfall)
B5 Avant AEB 07/2005 166.000km ( [email protected]) - 07/2007 195.000km (verkauft)
1K BMM: 03/2011 120.000 km - aktuell
Translated on 25-10-2026, 18:55.
faz Blaumann
1994 Audi 80 Premium Support
11-10-2004, 10:40 Subject: Tachometer Lighting: Improve Visibility & Safety |
The AI is very easy to expand.
Remove the upper handlebar cover (two Phillips head screws from the lower to the upper handlebar cover).
Two screws are visible on the instrument cluster; remove these, and the instrument cluster can then be taken out.
By tilting the dashboard backward, you can access the connectors, which you can then disconnect. Also, you can remove the instrument cluster without having to remove the steering wheel.
However, it's not easy to access the mileage counters. You'll have to remove and disassemble the speedometer, which can be quite risky. MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 25-10-2026, 18:56.
Profile PM Garage |
Martha Guest
11-10-2004, 11:27 Subject: Instrument Panel Lights Suddenly Dimmed |
In my A4, the instrument illumination is adjusted by turning the 'reset rod' of the trip odometer. I searched for a long time to figure out why the instrument and radio lighting suddenly became so dim after my son played in the car  .
I think that accidental twisting can easily happen when working on the combination instrument.
Martha.
Translated on 25-10-2026, 18:57.
