Tastverhältnis des Ladedruckventils
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post10-10-2004, 21:30    Subject: Quote
I've recently used VAG-Com to measure my values for boost pressure, MAF sensor, etc., and I've noticed that the ACTUAL boost pressure settles around 0.1 bar below the TARGET boost pressure after a surge (up to 2090 mbar). The boost pressure seems to be missing around 2400 - 4000 RPM. Does this now indicate a faulty boost pressure control valve icon_question.gif? Because the throttle position sensor seems to be fluctuating somewhere around 55%. That would leave enough room to adjust the boost pressure icon_question.gif
"But that shouldn't really have anything to do with the fact that my LMM is also starting to slow down again, right?"
Here's a visual representation.
http://img16.exs.cx/img16/1060/neu-5.jpg
http://img16.exs.cx/img16/1876/neu-6.jpg
Audi A3 Ambition, Bj.02, ASZ - SoftwareTuning 160PS
Multimedia-CarPC 2,4GHz - 1GB RAM - 300GB HDD - 8" Tochscreen
Back to top Profile PM Email
Karma: +786 / -0   Thank you, like it!
Post10-10-2004, 21:41    Subject: Translating...
[Translating...]
Luftmassensollwert müßte aber bei 850mg/Hub liegen, oder? 800 < 850...
Könnte also schon sein, daß der Ladedruck aufgrund Rauchbegrenzung so 'komisch' ist.
Mach doch einfach nochmal eine Meßfahrt mit der bekannten 'Luftmassenmesser-Ersatzdiode' bei abgeklemmter AGR (ausserhalb des öffentlichen Verkehrsraums wegen ABE Verlust).
Post10-10-2004, 21:58    Subject: Re: Pressure setting of the charging valve Quote
wbuchi82 wrote:
There is a lack of boost pressure between approximately 2400 - 4000 RPM. Does this now indicate a faulty boost pressure control valve icon_question.gif? Because the throttle position sensor is fluctuating somewhere around 55%. That would leave enough room to adjust the pressure icon_question.gif
Take a look here:
/viewtopic.php?t=7338
Your symptoms are similar in principle.
If the boost pressure is not achieved with the normal pedal ratio, there may be several other causes besides the VTG lever -> Technical article icon_wink.gif
wbuchi82
Post11-10-2004, 8:03    Subject: Translating...
[Translating...]
Danke für die Antworten!
Das mit dem LMM werd ich noch ausprobieren. Da mein Trekker auch beim vollgasgeben ein wenig zum rußen neigt zeigt das ihm etwas an Luft fehlt. Auch von der Leistung her fehlt mir ca. eine Sekunde auf den optimalen Wert des Durchzugstestes (ca. 7,2sec gemessen). Zuerst werd ich aber mal dem LMM auf die Sprünge helfen
MFG
No new posts Position des Ladedruckventils beim Golf IV Diesel Engine Technology
No new posts Tastverhältnis Ladedruckregelventil Diesel Engine Technology
No new posts Tastverhältnis - Klarstellung Diesel Engine Technology
