Disable Beep Sounds?
ckone
Post14-10-2004, 8:43    Subject: Disable Beep Sounds? Quote
Can the warning buzzer be disabled using VAG-COM?
I have a Polo 9N AXR.
'Thank you.'
Translated on 18-10-2026, 15:18.
Post14-10-2004, 9:26    Subject: Disable Beep Sounds? Quote
AFAIK no, you would need to intervene at the hardware level.
You can find a lot of information about the programming options in the tooltips of VAG-COM.
Theresias
Post14-10-2004, 10:32    Subject: Disable Beep Sounds? Quote
As far as I know, no, you would have to intervene at the hardware level.
Yes, there is no other option, but then all the summary messages will disappear.
Translated on 18-10-2026, 15:19.
ckone
Post14-10-2004, 20:41    Subject: Disable Beep Sounds? Quote
That's silly icon_sad.gif.
But still, thank you all.
No new posts Audi A3 8L: Replace Buzzer with Gong? Transmission, Chassis, Body & Interior
No new posts Light/bell - no function Transmission, Chassis, Body & Interior
No new posts Faulty Buzzer: Troubleshooting Guide Diesel Engine Technology
No new posts Disable AGR? Diesel Engine Technology
