Turbo Failure: Common Causes in Tuned Engines
Go to page: 1, 2  Next
Post14-10-2004, 15:25    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
In TDI engines that have been modified for performance, the turbocharger boost pressure is not increased as long as there is sufficient headroom within the pressure regulation limits.
However, the loaders operating in the maximum power range must ingest hotter exhaust gases than usual.
High exhaust temperatures can, as far as I know, cause the delicate VTG (Variable Turbine Geometry) mechanisms to warp and seize. This clarifies a possible cause of cargo hold failures related to tuning modifications.
Increased boost pressures in the higher engine speed range, resulting from chip tuning (or pressure sensor manipulation), quickly push today's small turbochargers with minimal reserve to their limits, meaning that the air intake velocity into the compressor approaches the speed of sound.
In this area, even significant increases in the pump speed only result in minimal further pressure increases.
"Given that tuners generally try to extract every last bit of power from the turbocharger, I assume that the turbochargers in most chip-tuned TDIs operate at or above their maximum RPM as specified by the manufacturer when running at peak boost pressure, resulting in increased exhaust temperatures."
My question: What types of charger damage typically occur due to over-revving?
Turbines torn apart by centrifugal forces?
Eaten waves?
Or or...?
Translated on 27-07-2026, 14:40.
Post14-10-2004, 18:34    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
I can imagine that due to the increased temperature and higher rotational speed, along with the associated greater centrifugal force, the angle of the blades may have slightly shifted towards a longer position. This could cause an unbalanced shaft to exert larger forces on the bearing, which would then expand it, and the subsequent collision between the blade and the loader wall would occur as a result.
My theory.
Translated on 27-07-2026, 14:42.
Post14-10-2004, 19:02    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
"In the event of overspeeding, the impeller shafts are designed to break."
Translated on 27-07-2026, 14:43.
Post14-10-2004, 19:07    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
Rainer K. wrote:
In case of overspeeding, the impeller shafts are supposed to break...
Hmm... do you know why?
Shear fractures caused by excessive transmitted torque, or rather, fatigue-bending-overload fractures?
As far as I recall, the inertial forces (and therefore the effects of imbalances) increase proportionally to the square of the rotational speed.
Post14-10-2004, 19:13    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
After all, the mass forces (and thus also the effects of imbalances) increase quadratically with the speed, if I recall correctly.
Because the waves are too thin? icon_cool.gif Sorry, I have no idea.
Translated on 27-07-2026, 14:45.
Gremlin
Post14-10-2004, 19:23    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
I would say it's likely caused by permanent or vibrational fractures due to excessive mass forces (imbalance).
At least our electric motors tend to fail in the torture chamber when they're over-revved.
There might also be resonance effects if the charger spins significantly faster than it's supposed to.
I could also imagine that the turbine would undergo plastic deformation if it were exposed to temperatures consistently above 100-150 Kelvin. This resulting imbalance would then cause the component to break apart.
CU Gremlin.
Translated on 27-07-2026, 14:46.
chris11
Karma: +3 / -1   Thank you, like it!
Post14-10-2004, 19:36    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
Considering the temperature gradients of the gas turbine in the direction of the shaft at full load, and that these vary depending on the load during cyclic operation, the turbocharger will be different after each run. The lifespan of the turbocharger is inherently limited by its design. If it is subjected to higher loads, its expected lifespan will not necessarily increase. It's rarely just a single weak point; often, there are multiple issues. Addressing these could result in a significantly better product. With a mature technology, one usually encounters several economically driven compromises.
Christian.
Translated on 27-07-2026, 14:48.
schnappi
Post14-10-2004, 19:54    Subject: Turbo Failure in Tuned Engines: Common Causes Quote
Here's the translation:
'The fact is that you cannot exceed the speed of sound with gas flows. Increasing the boost pressure, as a result, increases the density of the air. This allows for an increase in mass flow. Therefore, pre-compression of the air (two-stage supercharging) would be necessary. An additional pre-compressor (e.g., a compressor?) would then relieve the turbocharger. The increased exhaust gas temperature, in turn, reduces the density, which significantly increases the speed of the air. Does anyone know what the exhaust gas temperature is with and without a chip? Because for most materials, temperatures in the 450-degree range make a huge difference in fatigue life (according to Wöhler). In this range, even a 10°C increase can be comparable to approximately double the stress!'
Best regards, Olaf.
Translated on 27-07-2026, 14:50.
Gremlin
Post14-10-2004, 20:09    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
Source: MTZ 11/2002.
 File size:  37.25 KB
 Viewed:  4669 times
Translated on 27-07-2026, 14:52.
faz
Avatar-faz
1994 Audi 80
Post14-10-2004, 22:35    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
Turbochargers can fail quickly if they are operated below or above the specified fuel pressure limit.
In this process, vibrations occur in the compressor blades, which then lead to their breakage.
In the second scenario, excessively high rotational speed will be the cause of the rapidly increasing unbalanced forces.
http://www.turbodriven.com/de/turbofacts/images/img_21_principle_g.gif
Pump cutoff line, engl. surge line.
However, with diesel chip tuning, a lot of adjustments are made to the torque setting, resulting in a significantly increased maximum torque. In this case, the maximum engine speed limit is not exceeded due to the lower airflow through the turbine (which depends on the engine speed). Instead, the pump's limitations become more relevant.
Edit:
I've corrected the errors, thanks Ulf.
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 27-07-2026, 14:53.
donalexo
Post14-10-2004, 23:33    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
@schnappi:
icon_question.gif icon_question.gif icon_question.gif You've probably never heard of transonic flows. The critical pressure ratio required for them isn't that large. And with a Laval nozzle, it's very easy to reach supersonic speeds icon_wink.gif.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 27-07-2026, 14:55.
schnappi
Post15-10-2004, 6:19    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
@schnappi:
icon_question.gif icon_question.gif icon_question.gif You've probably never heard of transonic flows. The critical pressure ratio required for this isn't that large. And with a Laval nozzle, it's very easy to reach supersonic speeds icon_wink.gif.
Alex
'In my fluid dynamics lectures, I was taught that this Laval nozzle is specifically designed to decouple systems by using the speed of sound. Additionally, it was stated that gas flows cannot exceed the speed of sound. If this information is incorrect, please forgive me, and feel free to correct me.'
Translated on 27-07-2026, 14:56.
Post15-10-2004, 7:44    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
faz wrote:
Turbochargers can fail quickly if they are operated at or above their maximum operating pressure[img].
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
http://www.turbodriven.com/de/turbofacts/images/img_21_principle_g.gif[/img]
Flood level, English: surge line8O
Left is the pump curve, also known as the surge line.
The choke line is on the right side and can be identified by the decreasing RPM lines.
"In my opinion, the same information is also available on the BWT website..."
With diesel chip tuners, a lot is adjusted on the torque screw, meaning a significantly increased maximum torque. And in this case, the limit of maximum RPM is not exceeded due to the lower airflow of the turbine (which depends on the engine speed -> turbine). Here, the "clogging" limit plays a more important role. }
Are you referring to the pump's flow limit here? In other words, a high pressure buildup due to an (too) low mass flow rate?
Translated on 27-07-2026, 14:59.
faz
Avatar-faz
1994 Audi 80
Post15-10-2004, 14:39    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
Yes, of course...
I'm just wondering why I'm not going to bed when I can barely keep my eyes open and am struggling to focus on the monitor.
Surge line, pump curve.
Choke line, blockage limit.
The displacement limit will not play a role in our discussion (unless someone drastically increases the engine displacement icon_wink.gif).
MfG faz
Translated on 27-07-2026, 15:01.
Post15-10-2004, 14:54    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
I think it can play a role because it limits the mass flow through the compressor.
And that's precisely where the use of a turbocharger increases the mass airflow compared to a naturally aspirated engine -> The higher the boost pressure, the greater the mass airflow, even with the same displacement.
Am I using any technical terms incorrectly now?
Translated on 27-07-2026, 15:02.
Sepp
Post15-10-2004, 16:32    Subject: Turbo Failure: Common Causes in Tuned Engines Quote
In your discussions, a very important point is still missing. One of the most crucial and sensitive components of the turbocharger is the plain bearing system for the turbine/compressor wheel shaft. The radial bearings, and especially the axial bearings, are subjected to high loads. The compressor pressure ratio (pressure ratio - see further above in the compressor map) causes an axial thrust force on the axial bearing. If you operate with higher boost pressure, the load and wear on the axial bearing also increase. The consequences are that, due to increased clearance, turbine and/or compressor blades may rub against the housing contour, leading to a gradual loss of turbocharger performance, potentially resulting in complete failure. Similar damage can occur with an unstable radial bearing; often, imbalances and resonances above the standard permissible turbocharger speed are the cause. I don't want to go into detail about the function of the plain bearing system, as most people here are technically very knowledgeable. Just a reminder: use high-quality engine oil, and it really pays off to change the oil (always with a filter) more often than not.
Best regards from Sepp.
@Ulf - Technical terms are correct.
Translated on 27-07-2026, 15:04.
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts A3 Transmission Problems: 3rd, 4th, 5th Gear Not Working? Diesel Engine Technology
No new posts Wie kann ich feststellen, ob ein Lader kaputt ist? (G2 TD) Diesel Engine Technology
No new posts VP37: Common Issues & Problems in Old Age Diesel Engine Technology
No new posts MSA15 Control Unit: How to Identify a 1Z Model? On-Board Diagnostics (OBD)
