Injection Start Timing: Adjust with Diagnostic Tool?
joe
Post14-07-2002, 11:54    Subject: Injection Start Timing: Adjust with Diagnostic Tool? Quote
Hallo, ich habe mit dem Diagnosetool den Spritzbeginn gemessen. Im Leerlauf 2 Grad, sollte aber zwischen 6 und 13 Grad vor OT liegen. kann man den Spritzbeginn biem 1z TDI mit dem Diagnosetool einstellen? If so, how?
Thank you!
Translated on 08-09-2026, 12:24.
Post14-07-2002, 12:17    Subject: Injection Start Timing: Adjust with Diagnostic Tool? Quote
Are you sure about the 6-13° BTDC? I think that's typical for industrial engines, but my engine has an AHF (Air-Fuel Mixture) of about 2° BTDC at idle (without any ECU adaptation).
Based on my experience, the engine starts to make a noticeably louder knocking sound at 6° BTDC (Before Top Dead Center).
joe
Post14-07-2002, 16:51    Subject: I'm Not Sure! - Express Yourself Now Quote
Hello Rainer,
I have an installation manual for a VAG 1551 for an AFD engine. It states that the injection timing should be 6-13 degrees before top dead center (BTDC) at idle.
'Under full load, I've measured up to 11 degrees on my engine. The manual states that it should be between 6-13 degrees under full load. There might be an error in this manual. If you also have 2 degrees, I'll leave it as is.'
It actually runs smoothly and quietly when idling.
Translated on 08-09-2026, 12:26.
Post14-07-2002, 17:47    Subject: Injection Start Timing: Adjust with Diagnostic Tool? Quote
and how do you determine that the target values of another engine should be suitable for your engine?
/viewtopic.php?t=327
Translated on 08-09-2026, 12:27.
kasper
Post20-07-2002, 16:07    Subject: SEO: "Best German to English Translation Services" Quote
Read the value (fuel temperature > 40 degrees) and then loosen the pump. Loosen the front screw last. Then, turn the pump until it reaches the target value, and tighten the screws. Don't forget the screws on the fuel lines.
If the start of the funding period is delayed again, your pulley on the crankshaft is likely loose. This could soon lead to engine damage! Immediately remove the belt and check the crankshaft flange (the ribbed pulley may also be damaged).
Furthermore, I don't believe you're adjusting the start of the injection process... at most, you're adjusting the start of the flow... and the delay between those two is what's referred to as the injection delay.
Best regards, Jan.
Translated on 08-09-2026, 12:28.
Post20-07-2002, 20:10    Subject: Re: Absolutely! It's possible Quote
kasper wrote:
Furthermore, I don't believe you're adjusting the injection start, but rather the pump start... and the delay between those is the injection delay...
Hi, that's incorrect. The needle lift sensor allows for the determination of the start of injection, and this information is also provided by the engine control unit.
Translated on 08-09-2026, 12:29.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Can the diagnostic tool also be used for the 10-cent tuning? Diesel Engine Technology
No new posts Is the injection start time counted differently in PD? On-Board Diagnostics (OBD)
No new posts Issue with starting the spray gun, model VP37 Diesel Engine Technology
No new posts Injection start cannot be adjusted on the 1Z Upload
