No memory errors in T4 2.5 TDI engine, but still experiencing problems.
Klausen
Post18-10-2004, 9:30    Subject: No memory errors in T4 2.5 TDI engine, but still experiencing problems. Quote
Yesterday, we replaced the diesel ESP in a T4 ACV automatic 1999.
The car was started for a very long time with the faulty pump before it actually started running.
Now we have installed the other pump and have initially set it to static.
Then I tried to start it, but unfortunately, all that came out of the exhaust was white smoke.
However, I couldn't find anything in the error memory either.
Also, injection is also used.
What could it be?
On my T4 ACV 1997, the idle speed sometimes increases by 100 RPM earlier in the cold.
If I briefly restart the bus, it will be normal again.
No memory errors either.
What could it be?
I was able to already read errors with my DIY adapter and the Free VAG COM software.
Best regards, Klaus
Post18-10-2004, 10:32    Subject: No memory errors in T4 2.5 TDI engine, but still experiencing problems. Quote
Hello
Also, it can also be injected.
Not so perfect...
If I briefly restart the bus, it's back to normal.
Either normal because it's very cold with you or the coolant temperature sensor has a fault -> check values for plausibility.
Hello, Rainer
Klausen
Post19-10-2004, 8:18    Subject: No memory errors in T4 2.5 TDI engine, but still experiencing problems. Quote
Either normally because it's very cold with you or the coolant temperature sensor has a fault -> check values for plausibility
The outside temperature is unlikely to be the cause. Here, the temperature is still at least 5 degrees +.
I'm going to check the temperature sensor on my T4.
Maybe not quite as perfectly calibrated...
The other T4 is now running.
Can the adjustment instructions from the manuals be directly applied to the T4 2.5 TDI without any modifications?
Is there a separate diagram for ACV?
/viewtopic.php?t=3195
Hello Klaus
P.S. Hello Rainer. The screws for the case were put in yesterday.
Post19-10-2004, 9:01    Subject: No memory errors in T4 2.5 TDI engine, but still experiencing problems. Quote
There are several temperature sensors. Compare whether the values are approximately the same at cold start in the morning.
Regarding the diagram, yes, it's specific to engine codes. Therefore, you would need to compare them. To ensure the box actually gets into the pot in the morning, simply turn it a little more towards the morning, until it starts.
With the TDI Timing Checker, the adjustment should not be a problem icon_wink.gif
Hello, Rainer
Klausen
Post25-10-2004, 9:07    Subject: No memory errors in T4 2.5 TDI engine, but still experiencing problems. Quote
Hello!
Compare, whether they give approximately the same values in the morning with a cold engine.
I have. They show approximately the same thing. Only 1 degree difference.
Could it possibly also be due to dirt in the pump or injectors?
The idle increases only after the cold start.
If I restart the motor after about 2 minutes, the LL is back to normal.
It also happened once, when the engine was already warm, but the T4 had been standing there for about 1 hour.
With the TDI timing checker, the setting should not be a problem
I can therefore only verify the injection start time using the TDI Timing Checker.
With the unregistered version, there is no chance. Or?
Another question.
How can I, for example, {ACTION}?
Measurement Block 4, Field Number 4, Key Comparison. Fuel Injection Start Valve
Measurement block 1, field number 2, Injection start
extract
That's what VW is doing, essentially. Or?
Best regards, Klaus
Post25-10-2004, 9:44    Subject: No memory errors in T4 2.5 TDI engine, but still experiencing problems. Quote
Another question.
extract
Best regards, Klaus
Hello, the setting is performed as described in the technical article, via the measurement block 0.
Klausen
Post25-10-2004, 9:59    Subject: No memory errors in T4 2.5 TDI engine, but still experiencing problems. Quote
Sorry, I meant Measurement block 0 Field number 2 Injection start.
Post25-10-2004, 11:33    Subject: No memory errors in T4 2.5 TDI engine, but still experiencing problems. Quote
Also only available in the registered version. Otherwise, the story would be meaningless.
No new posts Adblue System Malfunction – No Error Code or 28653 / P204F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LWR Error: Unrecoverable Memory Corruption (Solved) On-Board Diagnostics (OBD)
No new posts Engine Problems? Workshop - No Error Codes Diesel Engine Technology
No new posts How to Clear Bluetooth Module Memory Electrical Systems, Vehicle Electronics, Multimedia
No new posts Throttle position error (G79) and boost pressure issues On-Board Diagnostics (OBD)
