Jerky movement, loss of top speed, and flickering display
CBSnake
Post23-04-2002, 18:34    Subject: Jerky movement, loss of top speed, and flickering display Quote
Okay, so I'm having the following problems with my 1999 Ibiza GT (1.9 110 hp): strong shaking/jerking during partial load, which disappears when the pedal is fully pressed, a top speed loss of about 10-15 km/h, increased fuel consumption by 1-1.5 liters, and the pre-glow indicator sometimes flashes after starting. Then, after turning off the ignition and restarting, it's normal again.
What could be the reason? I don't want them to replace unnecessary parts at the workshop. Thanks in advance.
'If any data is missing, please let me know where I can find it.'
Michael II
Post23-04-2002, 19:55    Subject: Re: Quote
The flashing preheating indicator suggests a fault that affects vehicle operation.
Sure, here's the translation:
"Please provide the text you would like me to translate from German to English."
As always in such cases:
Please have the error memory read out first (by a workshop or a friend with a diagnostic tool).
With the errors that have been identified, we can certainly help you further here.
Bye.
Michael II.
Post23-04-2002, 20:21    Subject: Re: Possibly. Pump failure Quote
CBSnake wrote:
So, regarding my 1999 Ibiza GT (1.9 110 hp), I'm currently experiencing the following problems: strong jerking during partial load operation, which disappears when the pedal is fully depressed; a top speed loss of approximately 10-15 km/h; increased fuel consumption by about 1-1.5 liters; and the preheating indicator sometimes flashes after starting. Then, after turning off the ignition and restarting, it's normal again.
What could it be? I don't want them to replace unnecessary parts in the workshop
Hi.
Based on my own recent experiences with a (deliberately) adjusted fuel injection control unit, the jerking and flickering remind me of a fuel injection quantity control unit that is no longer operating within its tolerance range.
Increased fuel consumption and loss of power, in my opinion, are more likely to indicate other problems, such as an EGR valve that is no longer closing properly or a clogged air filter.
Given the "vague" symptoms, I would definitely recommend checking the error memory (or having it checked). If it's blinking, there should be something displayed on it.
CBSnake
Post23-04-2002, 20:21    Subject: Jerky movement, loss of top speed, and flickering display Quote
Okay, so, I'm looking for a good workshop around here. If they don't do it, I don't have anyone else to ask. Do I need special equipment, like a software adapter and a laptop, or can it be done with just specific devices?
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPW Shaking on Audi A4 TDI: Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Jerking on Audi A6 C4 1.9 TDI Diesel Engine Technology
No new posts AU-AKN Lag: Troubleshooting & Solutions Diesel Engine Technology
No new posts Jerky A6 2.0 TDI PD Diesel Engine Technology
No new posts 1.9 TDI ASZ Misfire: Causes & Fixes Diesel Engine Technology
