Sharan Error: Why Your Car Goes Into Limp Mode
Alfi28
Post25-10-2004, 23:08    Subject: Sharan Error: Why Your Car Goes Into Limp Mode Quote
Hello everyone,
I'm having a problem with my Sharan, manufactured in 2000, which has 150,000 km on the odometer.
The engine has been chipped to produce 140 horsepower for the past year (factory output is 110 horsepower).
The EGR valve has been deactivated for approximately 15,000 kilometers.
Now it's happening more and more often that the engine cuts out when accelerating too quickly.
"The emergency mode is activated. A diagnosis using VAG-COM revealed the following errors in the control unit:"
Boost pressure differential.
2) Turbocharger boost control valve - short circuit to ground.
What's also worth noting is that when accelerating within a certain RPM range...
The car is making a lot of noise.
After that, I did a log using VAG-COM.
Perhaps someone can help me narrow down the source of the error?
STAMP mg/R % /min mbar mbar %
Row 1 Row 2 Row 3 Row 4 Row 5 Row 6
0 460 0 840 938 959 24.7
0.76 475 0 840 938 959 24.7
1. 52 475 0 840 938 969 24.7
2.28 465 0 840 938 959 24.7
3.04 460 0 840 938 959 24.7
3.8 470 0 840 938 959 24.7
4.56 480 0 840 938 959 24.7
5.34 470 0 840 938 959 24.7
6.12 475 0 840 938 969 24.7
6.92 485 0 840 938 959 24.7
7.67 470 0 840 938 969 24.7
8.43 475 0 777 959 969 24.7
9.19 465 0 819 959 969 24.7
9.95 450 4.7 924 1010 969 24.7
10.72 475 7.8 903 1020 969 24.7
11.48 450 8.6 1092 959 969 24.7
12.25 440 15.3 1281 1102 959 23.5
13.06 475 33.3 1932 1418 1020 21.1
13.86 540 29 2499 1183 1173 47
14.64 595 8.6 2037 1010 1142 37.9
15.39 500 0 1239 938 1040 28.7
16.15 470 12.2 1260 1061 1000 35.5
16.91 465 27.1 1449 1275 1010 21.9
17.67 520 25.9 1596 1030 1061 39.4
18.43 495 9.8 1575 949 1040 35.9
19.19 320 9.4 1470 938 1000 34.3
19.97 280 10.2 1449 1030 979 34.3
20.75 470 17.3 1533 1071 989 31.1
21.51 485 26.7 1680 1357 1051 19.9
22.27 555 42 1974 1652 1183 22.3
23.03 650 47.1 2373 2142 1448 23.9
23.79 1080 63.5 2877 2142 2091 53.8
24.55 1260 56.5 3213 1907 2183 67.3
25.31 1210 48.6 2814 1051 1805 38.6
26.07 545 19.6 2016 1805 1275 19.9
26.83 770 58 2142 2142 1622 23.9
27.59 815 34.1 2226 1346 1550 57
28.37 565 25.1 2268 1142 1336 57
29.13 440 20.8 2289 1102 1173 52.6
29.89 420 16.1 2226 1040 1112 43.4
30.65 310 0 2100 1020 1010 37.9
31.41 435 0 1932 1010 1010 37.9
32.17 445 0 1806 969 1000 37.1
32.93 445 0 1722 938 1000 36.3
33.69 450 0 1638 938 989 35.9
34.47 460 1.2 1554 938 989 35.5
35.23 435 13.7 1554 1071 1000 35.9
36.03 495 22.7 1617 1326 1040 19.9
36.83 540 36.9 1743 1520 1142 19.9
37.59 595 37.6 1890 1510 1244 22.3
38.35 635 34.1 1995 1285 1306 43.8
39.11 610 22.7 2079 1163 1244 45.4
39.87 475 27.5 2142 1683 1193 19.9
40.63 745 58 2352 2142 1632 29.5
41.39 1130 56.5 2562 1612 2030 94.4
42.16 610 0 2583 1051 1326 38.6
42.92 465 0 2478 1051 1091 38.6
43.69 450 0 2352 1040 1040 38.3
44.45 440 0 2163 1020 1030 37.9
45.21 435 0 1932 1010 1020 37.9
45.96 455 0 1701 938 1010 36.3
46.72 465 0 1533 938 1000 35.1
47.48 495 0 1365 938 989 33.1
48.24 465 0 924 938 1000 24.7
49 475 0 861 938 989 24.7
49.76 330 0 1029 938 979 24.7
50.52 410 0 1323 1010 949 32.7
51.28 475 32.5 1491 1387 1030 21.1
52.04 550 32.9 1785 1387 1173 23.5
52.8 630 33.3 2058 1612 1346 23.5
53.56 920 72.5 2604 2142 2050 61
54.32 1275 63.1 3192 2111 2519 71.3
55.08 1275 51.8 2982 1051 2081 38.6
55.84 610 28.6 2352 2142 1683 36.3
56.6 1275 100 2688 2142 2570 74.1
57.38 1275 100 3003 2142 2570 83.7
58.16 1275 100 3297 2142 2570 94
58.96 1275 100 3570 2142 959 94.4
59.76 830 0 2058 1010 959 92.4
60.52 750 52.2 2436 2142 959 92.4
61.28 800 100 2457 2142 959 92.4
62.04 820 7.1 2457 1040 959 92.4
62.8 490 0 2310 1030 959 92.4
63.56 440 0 2058 1010 959 92.4
64.34 445 0 1743 938 959 92.4
65.12 470 0 1176 938 959 92.4
65.88 470 0 840 938 959 92.4
66.64 370 0 840 938 959 92.4
67.4 300 0 945 938 959 92.4
68.16 240 5.5 1428 979 959 92.4
68.92 450 27.1 1701 1459 959 92.4
69.68 485 36.5 1953 1489 959 92.4
70.44 525 52.2 2268 2142 959 92.4
71.2 565 61.6 2583 2142 959 92.4
71.96 595 59.6 2856 2142 959 92.4
72.72 630 59.6 3150 1652 959 92.4
73.48 495 0 2226 1030 959 92.4
74.24 495 31 2142 1907 959 92.4
75 540 37.3 2184 1020 959 92.4
75.76 420 0 2163 1020 959 92.4
76.52 415 0 2100 1020 959 92.4
77.28 415 0 1995 1010 959 92.4
78.04 420 0 1911 1010 959 92.4
78.8 455 24.7 1932 1438 959 92.4
79.56 510 40 1974 1010 959 92.4
80.32 435 0 1869 989 959 92.4
81.1 450 0 1512 938 959 92.4
81.89 485 0 882 938 959 92.4
82.65 445 0 861 938 959 92.4
83.41 310 0 861 938 959 92.4
84.17 295 0 861 938 959 92.4
84.93 280 0 1155 938 959 92.4
85.69 280 12.5 1260 1173 959 92.4
86.45 455 31.4 1533 1224 959 92.4
87.24 475 23.9 1701 1173 959 92.4
88.03 495 25.5 1869 1244 959 92.4
88.83 495 32.5 2100 1520 959 92.4
89.59 525 37.6 2394 1469 959 92.4
90.35 565 35.7 2604 1142 959 92.4
91.11 470 0 1659 938 959 92.4
91.87 450 17.3 1722 1387 959 92.4
92.63 510 37.6 1806 1040 959 92.4
93.39 450 0 1785 959 959 92.4
94.15 435 0 1701 938 959 92.4
94.91 450 0 1512 938 959 92.4
95.67 465 0 966 938 959 92.4
96.43 470 0 861 938 959 92.4
97.19 335 0 840 938 959 92.4
97.95 300 0 840 938 959 92.4
98.71 290 0 840 938 959 92.4
99.47 265 0 840 938 959 92.4
100.23 275 0 861 938 959 92.4
100.99 280 0 840 938 959 92.4
101.75 285 0 840 938 959 92.4
102.51 275 0 840 938 959 92.4
103.27 290 0 861 938 959 92.4
104.05 290 0 840 938 959 92.4
104.83 285 0 840 938 959 92.4
105.58 290 0 840 938 959 92.4
106.34 300 0 840 938 959 92.4
107.1 285 0 840 938 959 92.4
107.87 290 0 840 938 959 92.4
108.63 290 0 840 938 959 92.4
109.41 290 0 840 938 959 92.4
110.2 285 0 840 938 959 92.4
111.01 290 0 840 938 959 92.4
111.79 295 0 840 938 959 92.4
112.54 285 0 840 938 959 92.4
113.3 285 0 840 938 959 92.4
114.06 285 0 840 938 959 92.4
114.82 290 0 840 938 959 92.4
115.58 285 0 861 938 959 92.4
116.34 280 0 840 938 959 92.4
117.12 295 0 840 938 959 92.4
117.88 425 17.3 2037 1275 959 92.4
118.64 415 0 1659 938 959 92.4
119.4 480 0 924 938 959 92.4
120.16 450 0 840 938 959 92.4
120.92 315 0 840 938 959 92.4
121.68 300 0 840 938 959 92.4
122.44 280 0 840 938 959 92.4
123.2 270 0 840 938 959 92.4
123.96 270 0 840 938 959 92.4
Translated on 18-08-2026, 12:05.
Thomas Falke
Post26-10-2004, 0:04    Subject: Sharan Error: Why Your Car Goes Into Limp Mode Quote
'Hi, I had the same problem. It only started happening after a while. In my case, it was the chip that caused my 2.5L TDI to go into limp mode. I had bought it from a cheap supplier.'
'But in my case, it appeared after only two weeks. So I replaced the chip again, put the old one back in, and then I went to a different dealer, got my money back, and took it to a proper mechanic.'
It's also quite possible that the issue is related to your EGR valve, as your mass airflow sensor might be misreading the air intake. With the EGR system active, the airflow should be lower under certain conditions, which may not be happening in your case. This could cause the sensor to report an error and trigger the limp-home mode.
Translated on 18-08-2026, 12:36.
joergs
Post26-10-2004, 7:19    Subject: Sharan Error: Why Your Car Goes Into Limp Mode Quote
Your logs are probably too complicated for anyone to easily understand. If you expect help, you should present the information in a clear and organized way, preferably as a diagram. Also, please include the relevant MWG postings.
Okay, now let's address your problem: you might find something in the troubleshooting section of the forum that could help identify the cause of these errors.
Based on your description regarding the black soot, I suspect there's a lack of boost pressure. Please investigate in that direction...
Translated on 18-08-2026, 12:37.
Post26-10-2004, 9:18    Subject: Sharan Error: Why Your Car Goes Into Limp Mode Quote
The error codes speak for themselves.
The pressure regulating valve is malfunctioning, and there's a difference between the setpoint and the actual value (at least, 2000 is different from 969 icon_smile.gif).
Okay, so check the valve -> perform a diagnostic test on the actuator, and while you're at it, also check the VTG solenoid with a stethoscope.
Use the search function for this.
Translated on 18-08-2026, 12:39.
Alfi28
Post26-10-2004, 22:01    Subject: Sharan Error: Why Your Car Goes Into Limp Mode Quote
I'll buy and install a new boost control valve tomorrow.
What might this part cost from Volkswagen?
I hope the problem lies in this part as well, but somewhere I need to...
Okay, let's start.
Translated on 18-08-2026, 12:40.
Post27-10-2004, 6:10    Subject: Sharan Error: Why Your Car Goes Into Limp Mode Quote
If you happen to be willing to spend a considerable amount, say over 200 EUR, for the valve, feel free to replace it icon_wink.gif.
It could also be due to the cable harness.
Before buying a new valve, I would first check everything.
If you use the forum search function, you'll also find that it's possible to temporarily use the EGR control valve that is no longer needed on your specific vehicle.
So, let's start the search, which might be difficult icon_wink.gif.
Translated on 18-08-2026, 12:41.
No new posts Transporter 7D: Brake Pad Wear Light Always On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts TDI Engine Problems: Emergency Mode Explained On-Board Diagnostics (OBD)
No new posts Golf 3 TDI: Engine Stalling While Driving On-Board Diagnostics (OBD)
No new posts 1Z Still Not Working: Troubleshooting Guide Diesel Engine Technology
No new posts 1Z engine keeps stalling while driving Diesel Engine Technology
