Hello everyone,
I've already searched the internet extensively for information on this topic, but I haven't found much.
With that in mind, I hope you can help me with this topic.
I plan to buy an older Passat (roughly from the year 1992 or later, diesel or TD model) to use as a 'workhorse' that I don't have to worry about as much (regarding scratches, dirt, etc.) as I do with my Golf.
Since the main factor for me when buying a second car is the cost, I plan to acquire a vehicle with engine damage or, at the very least, very high mileage.
My plan is to replace the engine and related components (including the engine control unit, transmission, etc.) with a used 1.4-liter TDI engine with the smallest possible displacement (keyword: taxes). I'm not concerned about performance in this vehicle, so I'm considering a '1.4-liter TDI' with 55 kW (75 hp) from VW, the same one that's used in the Polo.
Since I had never performed an engine conversion before, I had some questions.
- Does the 1.4-liter engine actually fit in the Passat?
- Was muss alles geändert werden? (Getriebe? Auspuffanlage? Engine mount?
- What costs should one expect for a 1.4L TDI engine? It can have quite a few miles on it.
- Is it something that can be done by someone with basic skills, or does it require a specialized workshop?
- Is it even possible to get an engine like that registered?
As you can tell from these questions, I am a complete beginner when it comes to engine conversions, but I am eager to learn, and I have plenty of time for this project over the winter
Okay, many newbie questions, I'm sure you can help me with those, as I've discovered there are plenty of experts here on board
Thank you very much!
