| Replacement of the upper seal on VP37 injection pump | ||||||||||||||
| Georg-TDI |
Here, you can download a report of mine in PDF format.
The described repair involves replacing the upper seal between the ESP cover and the MSW on a Bosch VP37 pump. This article should be interpreted solely as a private report. All work must be carried out at your own risk and responsibility. I hereby exclude any liability for any damages that may be caused. This report was created by Rainer Kaufmann for the forum www.dieselschrauber.de and is intended for internal information sharing within the forum only. Images and text may only be copied, cropped, quoted, and commented on within this forum. I will be notified as the author of this article of any further displacement. Author and copyright holder: Georg-TDI VCDS can be used to measure the start-stop values of the mass airflow sensor or the injection quantity at idle.
Translated on 03-07-2026, 14:19. |
| Ratings - Replacement of the upper seal on VP37 injection pump | |
Average rating: 4.40 - worst rating: 2 - best rating: 5 - number of ratings: 10 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.069s
