vagtuning Guest
28-10-2004, 18:25 Subject: Audi A3 1.9 TDI Starting Problems - 1998 |
The AHF (presumably a piece of equipment) starts up very poorly, sometimes making a noise for 5-8 seconds, even when it's warm.
For example, a small air bubble was noticed in the transparent tube.
When starting, it moves about 1 cm towards the pump, and then it stays in that position until the engine finally starts.
It's probably the pump that's broken, right?
Here are some idle values:
Default setting MWB 0:
43 65 0 23 102 201 77 154 112 144
'bzw.' is often translated as 'or' or 'respectively' in English. However, the best translation depends on the context.
Here are some examples:
* 'Ich mag Äpfel, bzw. Birnen.' - 'I like apples, or pears.'
* 'Die ersten drei Spieler, bzw. die ersten drei Teams, wurden ausgezeichnet.' - 'The first three players, respectively the first three teams, were awarded.'
In general, 'bzw.' is used to indicate that there are two or more options, and that the reader should choose the one that is most appropriate for the context.
43 61 0 24 101 201 67 147 119 104
Standard measurement value block display:
MWB 1:
900 revolutions per minute
4.4 milligrams per hour
1.660 volts
83.6 degrees
MWB 3:
900 RPM
285 mg/H
340 mg/H
69%
MWB 4:
900 U/min 1,3 v.OT 1,7 v. OT 2%
MWB 5:
900 21|6 mg/H 1.7 v.OT 83.9 degrees
MWB 10:
335 mg/H 999 mbar 1020 mbar 0.0%
MWB 13:
-0.02 mg/H -0.04 mg/H 0.32 mg/H -0.23 mg/H
Control unit: 038 906 018 BA, coding 0002, data version 1812.
Are there any suggestions before replacing the pump?
The vehicle has a manual transmission, no air conditioning, and no other accessories are activated.
Translated on 15-10-2026, 8:01.
Polo2004 Guest
28-10-2004, 18:46 Subject: Audi A3 1.9 TDI Starting Problems - 1998 |
Do you have any error codes? If the quantity sensor is showing an error, you can replace the fuel pump, or you can have it repaired by a Bosch service center (which is cheaper than buying a new one).
Best regards, Christian.
Translated on 15-10-2026, 8:04.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
28-10-2004, 19:23 Subject: Audi A3 1.9 TDI Starting Problems - 1998 |
Check if the control valve is being activated during the whining noise. It might be an electrical problem.
Translated on 15-10-2026, 8:05.
Profile PM WWW Garage |
vagtuning Guest
28-10-2004, 19:43 Subject: Audi A3 1.9 TDI Starting Problems - 1998 |
No, 0 memory errors!
Is the stop button being activated?
When starting, power must be supplied to the charging station, and as soon as the motor stops, the power is cut off? Is that correct?
Michelgott Guest
30-10-2004, 18:01 Subject: Many Options: Find Your Perfect Choice |
'There are many possible causes for your problem, such as temperature sensors, faulty fuel injectors, or a bad battery. I even once had a case where the starter motor was defective, and the starting speed was too low for the engine control unit (ECU) to start calculating. I have the same engine, and it doesn't start very well either. Also, I feel like it's lacking some torque in the lower RPM range (1200-1800 RPM) compared to other cars. Although I have a pretty good chip from Motorsport Schmid (it really performs well above 2000 RPM). If any of us finds a solution, we should definitely get back to each other, right?'
Best regards, Michelgott.
P.S. Do you already have a new power supply relay? (gray, part number 109)
Translated on 15-10-2026, 8:06.
vagtuning Guest
30-10-2004, 18:12 Subject: Audi A3 1.9 TDI Starting Problems - 1998 |
Feedback:
'New pump installed, no more air bubbles, and starting problems completely gone. The engine starts after 2-3 turns.'
The performance is really good again.
Translated on 15-10-2026, 8:08.
Michelgott Guest
30-10-2004, 18:15 Subject: Audi A3 1.9 TDI Starting Problems - 1998 |
Does yours also make a little noise when starting?
30-10-2004, 20:39 Subject: Audi A3 1.9 TDI Starting Problems - 1998 |
wieviel km hatte der Motor denn? Biodiesel/PPO?
Michelgott Guest
31-10-2004, 11:10 Subject: AHF: What is AHF? Definition & Explanation |
No, not biodiesel! 62,000 km.
Translated on 15-10-2026, 8:09.
