ESP Connectors: 8-Pin vs. 10-Pin
Post01-11-2004, 1:05    Subject: ESP Connectors: 8-Pin vs. 10-Pin Quote
Hi.
Here:
/viewtopic.php?t=1583&highlight=part+number+for+pump+connector
There are different part numbers for the 8-pin and 10-pin connectors of the ESP plug.
I can confirm the part numbers for the 8-pin version, as they work for me.
Since I also want to build a 10-pole version now, I'm wondering why my AKTE (presumably a piece of equipment or component) is malfunctioning with the 2x 5-wire configuration.
Does anyone know more?
Thank you.
Edit: Do the 10-pin connectors have different locating tabs? Is the distance 1.5 instead of 2.8 (what unit is that, whatever it refers to)?
Translated on 01-10-2026, 11:37.
No new posts ESP: Connect Contacts to 10-Pin Plugs Diesel Engine Technology
No new posts AGR Target vs. Actual: Differences Explained Diesel Engine Technology
No new posts LMM Curve: Troubleshooting Turbocharger Issues on VW T4 AHY On-Board Diagnostics (OBD)
No new posts DIY 10-Pin Adapter: Help Needed! Diesel Engine Technology
