Color-coded coolant temperature sensor
jonnycg2000
Post04-11-2004, 8:44    Subject: Color-coded coolant temperature sensor Quote
I need help; I'm looking for the exact function of the coolant temperature sensors in my car.
So far, I've identified a sensor with what appears to be two functions (one likely controls the temperature display, and the other the glow plug system), and four wires of different colors, which I'm not 100% sure about.
blue, violet, white-brown, green-brown.
VW.
Volkswagen Golf IV.
SDI.
Year of construction: 2000.
Model year 2001.
AQM.
Post04-11-2004, 10:25    Subject: Color-coded coolant temperature sensor Quote
1. Buy a repair manual; it contains the wiring diagrams.
(z.B. "This is how it's done")
2. Poel in DI is not easy - but you probably know that already icon_wink.gif.
3. Unfortunately, I have no idea what the cables look like inside the G4, because I have a G3 (with the manual icon_smile.gif).
Karma: +442 / -0   Thank you, like it!
Post04-11-2004, 20:15    Subject: Color-coded coolant temperature sensor Quote
Golf IV, engine code AQM, manufacturing month 01.
According to the VW program, the following colors should be available:
The blue/white and green wires (Pin 3/4) connect to the EDC.
purple and brown/white (pin 1/2) connect to ground and the combination instrument.
Guste.
No new posts Coolant Temp Sensor vs. Diesel Temp Sensor for AJM PD Diesel Engine Technology
