A6 2.5 AEL: No More Proper Pull-Through:-((
madcatxyl
Post19-07-2002, 5:54    Subject: A6 2.5 AEL: No More Proper Pull-Through:-(( Quote
Hello everyone,
I've recently been having some problems with my car: an Audi A6 2.5 TDI AEL (200,000 km).
Error description:
In my opinion, the engine has less power throughout the entire RPM range. Also, it recently started leaking coolant from the filler cap. I had it checked to see if there was any exhaust gas in the coolant => the result was negative. The compression is consistent at 28-28.5 bar. I then replaced the cap and the coolant regulator, and since then, there have been no more issues (I thought the head gasket might be damaged).
How would you approach troubleshooting a loss of power? (Oh, and there are no error codes stored.)
Translated on 21-10-2026, 12:08.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 1.9 TDI not pulling properly Diesel Engine Technology
No new posts Passat 3C 125kW not pulling properly Diesel Engine Technology
No new posts AHU 66kW: Troubleshooting & Repair Guide Diesel Engine Technology
No new posts A6/AEL: Why No Speed Above 3000 RPM? Diesel Engine Technology
