Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z
Go to page: 1, 2  Next
Alfajunkie
Post22-03-2006, 19:54    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
hello,
Since I'm still having problems with my STH Thermo Top C/Z, I now want to replace the burner (STH burner doesn't always work, but does after the automatic release).
I now have the opportunity to purchase a burner unit for the thermo top C/Z at a low price. However, it would require gasoline. My car is equipped with a STH for diesel fuel.
Could you tell me if there are any structural or functional differences between the two burner inserts?
The Webasto E-numbers are different.
Thank you for your response.
Hello
alfajunkie
wolfi_b
Post23-03-2006, 8:10    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
Hello
I've just read your old thread.
Have you ever read out the error codes? You can also do this yourself. Diagnostic adapters are available cheaply in the shop, and the software can be downloaded from Webasto.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
fricki
Karma: +7 / -3   Thank you, like it!
Post24-03-2006, 8:37    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
As far as I know, the burner is the main distinguishing feature of portable heaters.
In a diesel engine, the fuel is applied to a felt, where it evaporates, and then ignited by the glow plug.
The gasoline engine is directly placed onto another piece of cloth, and then ignited using a type of spark plug.
Alfajunkie
Post24-03-2006, 14:24    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
hello,
I haven't yet checked the fault memory. Although the STH is starting, it doesn't always burn but only on the second or third attempt. I suspect there are residues in the burner that are preventing the diesel from igniting.
I doubt that this is noted in the error log.
The gasoline burner is on the move.
I'll see if there are any major differences.
Hello
alfajunkie
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post25-03-2006, 20:15    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
Have you already disassembled your space heater? I had a similar problem, I had a Webasto heater, rebuilt with different electronics + control panel (since it was for Mazda with CAN-Bus), it was completely clogged! Cleaned, assembled, and it worked perfectly!
Stummel
Post25-03-2006, 23:38    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
Hiho
In the gasoline combustion chamber, there is also a filter at the back that looks like a fuel injector cleaner. And in front of it is the glow plug. If the camera would work, I could take pictures.
wo kann man denn auf der Webasto-Seite das Programm zum Auslesen finden? und funktioniert das auch mit Eberspächer Heizungen?
Alfajunkie
Post26-03-2006, 11:14    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
hey gremlin,
I had already disassembled the STH. I also hoped that cleaning would fix the problem. However, it unfortunately wasn't enough.
Hello
alfajunkie
wolfi_b
Post27-03-2006, 7:51    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
Stummel wrote:
Where can I find the program to read out the data on the Webasto website?
And does it also work with Eberspächer heaters?
No, just for Websto.
http://bus.webasto.de/support/de/support_applications.html
1993 Audi 80 B4 1Z
Alfajunkie
Post30-03-2006, 16:00    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
hello,
Okay, I have now received the gasoline burner and have found that the connection for the glow plug/flame guard does not match the connection for the diesel burner.
Secondly, there was a wire, approximately 1 mm in diameter, in the fuel line. However, I don't think this was a problem.
Unfortunately, I now have a brand new burner available.
If anyone is interested, they can contact me.
Hello
alfajunkie
ps: At the old Brenner, there were again significant accumulations. Could this possibly be due to potentially short Brenner operation times?
Alfajunkie
Post26-04-2006, 11:26    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
hello,
as I now know, the procedure for installing the flame arrester on new burners (gasoline and diesel) has changed.
Can anyone tell me where I can get a new, suitable glow stick?
My Webasto dealer only offers complete burner and glow plug sets!!
hello
alfajunkie
Alfajunkie
Post24-05-2006, 11:28    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
After I had 'adjusted' my 'old' glow stick for the new combustion chamber, the STH started working properly.
I will be observing the situation and will get back to you periodically.
hello
alfajunkie
Alfajunkie
Post03-09-2006, 10:37    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
hello,
I wanted to get in touch again.
it seems that the combustion chamber is indeed a wear-and-tear part. unfortunately, Webasto does not offer the combustion chamber and the glow plug separately.
{FRUIT}
alfajunkie
wolfi_b
Post04-09-2006, 7:10    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
Have you installed the gasoline combustion chamber yet?
1993 Audi 80 B4 1Z
Alfajunkie
Post04-09-2006, 11:46    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
hello,
yes, for testing purposes, I would occasionally turn them on. Isn't that also recommended by Webasto?
Between the gasoline and diesel combustion chambers, I observed no discernible difference.
hello
alfajunkie
Maxx1278
Avatar-Maxx1278
Post13-12-2006, 9:00    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
Hello everyone!
What actually happens if a SH (Schiffs-Hybrid) is powered by diesel fuel with gasoline?
Please provide information!
LG
Maxx
Alfajunkie
Post13-12-2006, 19:11    Subject: Unterschied Webasto Brenner Diesel/Benziner Thermo Top C/Z Quote
hello,
I have a gasoline combustion chamber with diesel fuel in use. So far, I haven't been able to detect any difference.
as far as I know, the difference between gasoline and diesel is only the frequency of the fuel pump!
but this information is provided without warranty.
hello
alfajunkie
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Webasto Thermo Top C On-Board Diagnostics (OBD)
No new posts Webasto Thermo Top with CAN Bus: Installation & Guide Transmission, Chassis, Body & Interior
No new posts Webasto Thermo Top: Standheizung für Autos Diesel Engine Technology
No new posts Webasto Thermo Top: Outside temperature sensor Transmission, Chassis, Body & Interior
