AKU 1.7 SDI & N108: Specs & Info
Post13-11-2004, 13:03    Subject: AKU 1.7 SDI & N108: Specs & Info Quote
Hi.
I have an AKU (presumably a type of injection system) that injects a very aggressive 27 degrees before top dead center.
(Awesome sound, that trekker icon_evil.gif).
The N108 is not responding to the basic settings in block 004.
It sounds like a fairly simple issue, probably a faulty N108 sensor.
"NUR:"
Why doesn't the PWM duty cycle change in block 004 if the device is supposed to oscillate between late and early?
It remains at 54%, even though "late" and "early" alternate in field 2?
Shouldn't the actual start position remain the same in case of a defective valve, while the PWM signal fluctuates up and down?
Translated on 30-08-2026, 18:26.
No new posts 1Z SBV - N108 On-Board Diagnostics (OBD)
No new posts N108 Control: How to Operate & Troubleshoot Diesel Engine Technology
No new posts AFN Engine Control: N109/N108 Modules Diesel Engine Technology
No new posts Fuel Injector Valve N108, Bosch 0281002136 Diesel Engine Technology
