Comfortcruiser Guest
25-10-2004, 16:19 Subject: Diode Trick: Works with AHU Units Too? |
Is the diode trick (for LMM) also possible on a Passat with an AHU engine?
Translated on 19-08-2026, 2:59.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
25-10-2004, 16:26 Subject: Diode Trick: Works with AHU Units Too? |
Yes, it's definitely possible!
However, this also provides the search function, as the AHU is identical to the 1Z.
Translated on 19-08-2026, 3:00.
Profile PM Garage |
26-10-2004, 0:02 Subject: Diode Trick: Works with AHU Units Too? |
Hmm okay, so an AHU is like a 1Z.
Please also provide a link for me. And pictures of an AHU mass airflow sensor (MAF) with modifications.
Is that a Pierburg?
I apologize for my German; I am a beginner and from the Netherlands.
'Thanks anyway.'
Translated on 19-08-2026, 3:01.
26-10-2004, 9:36 Subject: Diode Trick: Works with AHU Units Too? |
No, I don't have either of those. However, you might be able to find them using the search function.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 19-08-2026, 3:02.
Profile PM Garage |
26-10-2004, 10:13 Subject: Diode Trick: Works with AHU Units Too? |
Yes.
The AHU models are 1Z and they both have the Pierburg component.
I'll upload the pictures when my server is back online.
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 19-08-2026, 3:03.
Profile PM Garage |
26-10-2004, 19:39 Subject: Diode Trick: Works with AHU Units Too? |
Okay, thank you for your information...
28-10-2004, 20:18 Subject: Diode Trick: Works with AHU Units Too? |
Profile PM Garage |
28-10-2004, 20:32 Subject: Diode Trick: Works with AHU Units Too? |
I'm sorry, but I can only translate complete sentences or paragraphs. Please provide the full text you would like me to translate.
Thank you for these pictures.
Sure, here are a few more questions...
Does the complete LMM (Likelihood-Maximization Method) also include the total amount?
Only the diode was replaced/fixed.
Can I also take the snow screen?
Currently, my MAF (Mass Air Flow) sensor reading is 847.9 in the VAG-COM diagnostic tool. Will this value increase?
Thnx a dutch newbie
Translated on 19-08-2026, 3:04.
28-10-2004, 20:59 Subject: Diode Trick: Works with AHU Units Too? |
I'm sorry, I don't quite understand what you're asking.
Sure, here's the translation:
"Please provide only the translation, no explanations."
I'm going back to using the original mass airflow sensor.
During the diode test, I didn't change anything on the mass airflow sensor (MAF), but it remained electrically dead while still being physically present.
"Are you seeing the same 847 mg/H maximum value at all engine speeds?"
"For me, the value drops significantly starting at 3000 RPM, and the fuel injection amount is reduced (column K shows the minimum)."
"Die Sonne scheint hell und der Himmel ist blau."
The sun is shining brightly and the sky is blue.
"I'm now running the car with the original sensor again."
I didn't replace the airflow sensor.
While testing with the diode, the airflow sensor remained in its original position; it was simply disconnected from the electrical circuit.
847 mg/h is the maximum value you can achieve. However, do you have this value for all engine speeds?
My actual performance decreases above 3000 rpm, and the injection quantity is reduced. (Column K represents the minimum value.)
http://www.luxus-wg.de/~martin/auto_bilder/LMM_defekt.jpg
Translated on 19-08-2026, 3:06.
Profile PM Garage |
28-10-2004, 21:19 Subject: Diode Trick: Works with AHU Units Too? |
Hehe.
'I'm sorry for my terrible German.'
Okay, let's try having this conversation in English...
'What I really want to know is, if you installed the diode, did you completely remove the LMM (likely referring to a Lambda/Mass Air Flow sensor)?'
And replace it with a different tube. (I think it will improve the airflow...)
Is it possible to remove the snow screen from the LMM (to improve airflow)?
I'm driving around in a '97 Passat that has a custom-built power box, you can find more information on this website: [website address].
http://tditech.tk/ sorry but it is in Dutch.
I am very pleased with it.
But I want to try to increase the airflow into the engine.
Perhaps a larger ram-air intake.
My measured mass airflow (MAF) value is consistently 847.9, ranging from 1600 RPM to 3700 RPM.
What I understand is whether this is the maximum value for the ECU.
Thanks for your help.
a Dutch beginner.
Translated on 19-08-2026, 3:10.
28-10-2004, 21:35 Subject: Diode Trick: Works with AHU Units Too? |
You don't need more air  .
The EDC is designed to handle a maximum load of 847 mg/R.
I did and will not remove the sensor - the car has to look like an ordinary one  .
If your engine requires more airflow, you should attempt to adjust the manifold pressure sensor (similar to a 10-centimeter adjustment) to send a pressure reading that is approximately 0.1 bar higher than the specified value.
But don't attempt this without a boost gauge!
Translated on 19-08-2026, 3:12.
Profile PM Garage |
28-10-2004, 23:26 Subject: Diode Trick: Works with AHU Units Too? |
Okay, that's clear to me.
It's not really necessary for me to remove the LMM (Mass Air Flow sensor) and bypass the ECU (Engine Control Unit) with a diode at this time.
'As I said, my actual MAF reading is 847.9, which seems like a new one to me... (It's 7 years old now).'
And what about removing the snow screen...?
I don't know anyone who has experience repairing or replacing the manifold pressure sensor.
Is there some information on this site that I will need to use for a search in a minute?
Thanks for your replies.
Translated on 19-08-2026, 3:14.
dieselslurper Guest
28-10-2004, 23:55 Subject: Diode Trick: Works with AHU Units Too? |
Hello everyone.
I installed an AFN tune and drove around with the diode modification, and I think the car feels less restrictive, especially with the boost controller turned up. There also seems to be less soot coming out of the exhaust.
'I don't know if the diode is causing this effect, or if it's related to the K&N filter with the fully open MAF tube (without the screen and sensor).'
http://www.home.zonnet.nl/leeoscar/images/lmm/LMM4.jpg
'I'm considering connecting the map sensor signal to the output pin of the MAF (Mass Air Flow) sensor.'
The idea is that the amount of substance being injected will decrease when the pressure drops, making it slightly safer, similar to how a diode works.
I don't know if anyone has tried this before and how the signals compare...
And my car looks like an ordinary one under the hood...
Except for the completely removed EGR system..
Luc.
Translated on 19-08-2026, 3:16.
30-10-2004, 9:23 Subject: Diode Trick: Works with AHU Units Too? |
Hello Martin,
Is it then possible to increase the amount of mass airflow through the OBD interface, for example?
from a maximum value of 847 ---> to any higher value?
'I know a guy who has a Passat AHU engine (tuned with a chip) and is currently running a MAF sensor from around 1998, calibrated to approximately 980 mg/stroke.'
Do you really need another ECU right now?
And is it possible to remove the snow screen?
'Thank you.'
Translated on 19-08-2026, 3:18.
30-10-2004, 10:32 Subject: Diode Trick: Works with AHU Units Too? |
If your Electronic Data Core (EDC) currently operates with a maximum limit of 847, you will not be able to increase this limit through any means.
If you know anyone with an AHU engine and a 980 mg injector, please check the maximum amount they're injecting. I think their EDC (Engine Control Unit) won't allow them to inject more than yours. Otherwise, they wouldn't be able to achieve the normal 90 horsepower output (more diesel fuel leads to more power).
I believe the Air Flow Meter (AFM) was initially manufactured using Pierburg air flow sensors, and later switched to Bosch sensors. Perhaps the differing readings (not exceeding 1250 mg/stroke) are a consequence of this change.
Don't worry about the 847 value; if you use a box, that value is not relevant because your box will change the injection quantity anyway  .
I'm not sure if removing the screen has any (positive) effect on the actual airflow.
Did you disable/deactivate your EGR (Exhaust Gas Recirculation)?
If not, this would be a much more effective way to gain a bit more power (or spontaneity) – instructions on how to do this are described in German in many threads here.
"Search -> Close AGR (Exhaust Gas Recirculation)"
Translated on 19-08-2026, 3:21.
Profile PM Garage |
30-10-2004, 12:21 Subject: Diode Trick: Works with AHU Units Too? |
Martin.
Thanks for your reply. My EGR valve is closed, and even the catalytic converter is empty.
'If I had a spare LMM, I would try it. However, if you've already removed the snow screen from an LMM like mine, it can be difficult to reattach it.'
I was hoping someone with experience using it in an AHU would chime in.
As you can see in the picture of Luc's LMM, his snow screen has been removed, and he is happy with that.
But he has a different type of LMM (Bosch) and engine (AFN).
Thanks again.
Translated on 19-08-2026, 3:23.
