Timing belt replaced on a 1Z engine, year of manufacture 1996
Wolf-Dietmar
Post23-11-2004, 13:33    Subject: Timing belt replaced on a 1Z engine, year of manufacture 1996 Quote
I replaced the timing belt after 100,000 kilometers.
Condition of the timing belt: Very good.
Condition of the tensioner pulley (Ruville): Slight play in the bearing.
Condition of the idler pulley (still original VAG): No play.
Condition of the Conti ribbed belt (with A/C): Severely worn. Broken ribs. Now I finally know where that strange noise was coming from when idling. I had already replaced the tensioner roller, which would have saved me some trouble.
Piston stroke after installing the new belt: 0.48 mm. It had to be readjusted.
I had loosened the camshaft sprocket to allow for the installation of the belt.
I had a huge problem with the right-hand screw (stud bolt/set screw) of the lower timing cover, which had come loose. It took me 2 hours to find a way to get that screw back in without having to completely disassemble the engine.
Question: What are you doing with this screw? icon_rolleyes.gif
Translated on 15-07-2026, 12:01.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Replacement: Cost & Procedure Diesel Engine Technology
No new posts Crankshaft Screw Replacement for AAZ Engine Diesel Engine Technology
No new posts Timing Belt Interval AFB/AKN Engine Diesel Engine Technology
No new posts Timing belt snapped on the SDI! Diesel Engine Technology
