TDI Engine: Troubleshooting & Solutions
Zwewwel
Post20-11-2004, 20:21    Subject: TDI Engine: Troubleshooting & Solutions Quote
icon_cry.gif Since today, my Passat TDI is acting up. 1Z, manufactured in 1995. This morning, I started the engine, and suddenly it started smoking for about 1 minute, like a fog machine. Afterwards, it ran without any problems. After the oil change (which was due), the engine ran normally, but then, when I was driving home, the engine suddenly revved up to 5000 RPM (with a huge white cloud of smoke) and wouldn't turn off with the key; I had to stall it. This happened 3-4 times. When I drive, it emits white smoke during the ride. After 10 minutes, it runs without any problems, doesn't smoke, and has full power. It doesn't have any water loss.
Does anyone have any advice?
Translated on 24-09-2026, 4:06.
Post20-11-2004, 22:14    Subject: TDI Engine Revving: Troubleshooting & Solutions Quote
Zwewwel wrote:
The engine suddenly revved up to 5000 RPM (with a huge cloud of white smoke) and wouldn't turn off with the key;
I had to stall it.
Actually, this is the classic symptom of a diesel engine that's burning engine oil.
So the question is, how does this stuff get into the intake manifold? Often, the turbocharger is the source (unfortunately, because it's an expensive repair).
Translated on 24-09-2026, 4:07.
Avatar-Jan6K
Post20-11-2004, 22:51    Subject: TDI Engine: Troubleshooting & Solutions Quote
Who performed the oil change? With a TDI, it's easy to make a mistake if you give it gas immediately after starting it up. In that case, the turbocharger will spin up without being lubricated, which could be the cause of what Ulf is describing.
I definitely wouldn't drive it anymore until the issue is resolved. Be glad that it only reached 5000 [RPM], and nothing worse happened.
Jan.
1Z5 CFHF / AHB H4D
Translated on 24-09-2026, 4:08.
Zwewwel
Post21-11-2004, 10:36    Subject: TDI Engine: Troubleshooting & Solutions Quote
The problem occurred even before the oil change. I performed the oil change myself and let the engine idle until the warning light went off.
'We can't detect any oil leaks, and we replaced the turbocharger this morning with a spare one. However, it's still smoking.'
Translated on 24-09-2026, 4:09.
No new posts Engine Revs High After Warm Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Engine Misfire: 1Z Won't Accelerate On-Board Diagnostics (OBD)
No new posts VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission Transmission, Chassis, Body & Interior
No new posts Engine Revs High on Warm Start? Diesel Engine Technology
No new posts DPF Smoke: Passat 3C Engine Revving Issues Diesel Engine Technology
