Motor Control Power Relay: Reliable & Efficient
Klausel
Post25-07-2002, 14:04    Subject: Motor Control Power Relay: Reliable & Efficient Quote
Hello!
During a continuous test with a TDI 110 hp engine (Skoda Octavia), the vehicle stopped because the aforementioned relay was defective.
I own a G3 (7/97) with 110 horsepower (AFN engine). I read somewhere that Volkswagen eventually replaced the original relay with a more robust one.
Who knows if and when that happened.
Is this the part with the famous number 109?
Greetings, Klaus.
Translated on 24-09-2026, 6:18.
Michael II
Post25-07-2002, 14:11    Subject: Motor Control Power Relay: Reliable & Efficient Quote
Try searching the error database.
Tschüss
Michael II
Translated on 24-09-2026, 6:19.
Klausel
Post25-07-2002, 15:00    Subject: Motor Control Power Relay: Reliable & Efficient Quote
Yes, I know: "Think before you click."
I tried that too, but the part was referred to as a "power supply relay" and not a "voltage supply relay" in the cited test.
I somehow managed to find it anyway.
"Thank you very much!"
I can't find the article using the search term "Spannungsversorgungsrelais" - is there perhaps a problem with the length of the search term?
Greetings, Klaus.
No new posts Reset Engine Control Unit (ECU) - How To Diesel Engine Technology
