Incandescent bulbs at AUY
Dirk_S
Post05-12-2004, 0:42    Subject: Incandescent bulbs at AUY Quote
Hello and a beautiful second Advent to the forum!
I would like to have the bulbs checked in my Alhambra (AUY) sometime, as I suspect that one of them is not functioning correctly.
Just one silly question: I took a quick look under the hood today, but didn't find anything at first (I of course removed the cover and insulation). Where are the glow plugs located at the AUY (presumably referring to the engine compartment)? Or, how do I get to them? In my Skoda (ASV), I was able to see them without any problems. Maybe I just had tomatoes in my eyes.
I would be grateful for any tips or images. The valve head cover (the plastic part) doesn't necessarily have to be removed, does it?
Greetings
Dirk
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Spark plug firing order Technical Data
No new posts Werkstattaktion 2D, Glühkerzen-STG tauschen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glühkerzen beim 1z Diesel Engine Technology
No new posts Abgebrannte Glühkerzen beim alten 1,6er VW-Motor Diesel Engine Technology
No new posts Will the Audi A4 B7 170 PS TDI engine have a problem? Bul... On-Board Diagnostics (OBD)
No new posts Glow plug behavior in a Golf III TDI 81kW engine On-Board Diagnostics (OBD)
