Tuned 1Z Engine Temperature with Laptop
turgumu
Post05-12-2004, 23:57    Subject: Tuned 1Z Engine Temperature with Laptop Quote
Yesterday, I had the opportunity to record certain data on my 1Z car using a laptop while driving.
The engine has been modified with a turbocharger running at 1.1 bar of boost pressure and injectors from a 5-cylinder TDI engine, along with a custom chip.
The test duration was approximately 5 minutes on the A31 highway, accelerating from 100 km/h to 208 km/h according to the speedometer.
The data during the journey.
Top speed according to the laptop: 198 km/h (208 km/h according to the speedometer).
'The intake air temperature remained at approximately 39°C (outside temperature ~3°C), despite using maximum engine speed.'
Oil temperature: ~126°C
Injection angle 17.4° relative to the top dead center (TDC) at maximum speed.
What pleasantly surprised me is that the intake air temperature remained constant at 39°C.
while the engine was constantly getting 'hotter,' including the oil temperature, which reached 126°C.
I had the impression that the intake air temperature could rise up to 70°C, even on cold days. This is because, as a 1Z engine, the engine was subjected to a significant amount of power demand.
Does anyone happen to have information about the injection angle for a standard 1Z engine? The actual injection angle doesn't always match the values provided in some magazines or documents.
Translated on 09-10-2026, 16:20.
wolfi_b
Post06-12-2004, 8:43    Subject: Tuned 1Z Engine Temperature with Laptop Quote
turgumu wrote:
Does anyone perhaps have information about the injection angle, specifically the standard values for a 1Z engine?
According to the scientific articles:
http://www.dieselschrauber.de/Solldaten_4_Zylinder_VE.html
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 09-10-2026, 16:23.
turgumu
Post06-12-2004, 17:44    Subject: Sprinkler Start: When to Begin Sprinkling? Quote
I also looked at the technical article, which states that at full load, the injection timing is 8-12° BTDC (before top dead center), using the same reference as the AFN engine. However, I also know that, for a standard AFN engine (as read from the engine management system), the injection start timing at full load was 15.4° BTDC!
Or, something that just occurred to me, could it be that these values apply up to the maximum RPM, which is 4000 RPM?
Rudi
Post06-12-2004, 17:55    Subject: Tuned 1Z Engine Temperature with Laptop Quote
The injection start occurs at angles up to 15.08° for engines 1Z and AFN (MSA15; target air-fuel ratio; possible corrections not considered).
where data rounded to 8 bits are transmitted as part of the diagnostic process (displayed as 15.4).
(so it may be).
Best regards, Rudi.
Translated on 09-10-2026, 16:25.
No new posts Golf TDI Exhaust & Catalytic Converter 1Z Diesel Engine Technology
No new posts Lieber ein jüngeres Auto, oder eins mit weniger Kilometern? Diesel Engine Technology
No new posts VAS software on a laptop? On-Board Diagnostics (OBD)
No new posts Minimal laptop for VAGCOM? Diesel Engine Technology
