Run 1Z without muffler? (SEO optimized)
Jan03
2010 Volkswagen Polo
Post17-12-2004, 10:06    Subject: Run 1Z without muffler? (SEO optimized) Quote
Hello.
"I've removed the ESD (Exhaust Silencer Device) and I wanted to drive around for a while before getting a new one. The ESD doesn't affect the volume on the 1Z engine, but the pipe from the MSD (Multiple Spark Discharge) ends right next to the fuel tank, which is made of plastic. How hot do the exhaust gases get? Is there a risk of something starting to melt?"
/Jan
Translated on 17-10-2026, 8:06.
Post17-12-2004, 10:12    Subject: Run 1Z without muffler? (SEO optimized) Quote
I wouldn't do it.
You have absolutely no control over what might be happening under your tractor. Eventually, you'll come to a stop because the tank is empty, and you'll have left a trail of oil all over the road for the last few kilometers.
If you're going to do it, then at least use a replacement pipe – but building and attaching that is probably more complicated than just buying a new exhaust system.
m
Why did that one fail? My ESD is turning 9 years old tomorrow and is still working fine!
Translated on 17-10-2026, 8:08.
Rudi
Post17-12-2004, 10:29    Subject: Run 1Z without muffler? (SEO optimized) Quote
Hello Jan,
Ideally, there should be a thin aluminum foil component between the exhaust and the underbody; it's called a heat shield.
I recently drove for over three weeks without an ESD icon_cool.gif - nothing burned out.
Best regards, Rudi.
edit:
@Martin
you were faster icon_biggrin.gif.
I've already installed the third ESD (Electronic Stability Device), although my car is only a few months old.
younger than yours.
This one will probably outlive the car now (thanks to the stainless steel) icon_mrgreen.gif.
Translated on 17-10-2026, 8:09.
DocSnydor
Post17-12-2004, 10:41    Subject: Run 1Z without muffler? (SEO optimized) Quote
'Don't do that. I already tried that with my Passat once. Also, my EGR valve is faulty. I simply attached a 90-degree bend pointing downwards. Unfortunately, I lost it without realizing it. The result was that the underbody protection was as liquid as water and leaked out of the sill. Moreover, the brake force distributor was also in the way. The exhaust fumes heated the brake fluid so much that pressing the brake pedal did nothing. However, I must also say that this happened on the highway. If you're only driving around town, it should be somewhat okay... Still, be careful!'
Translated on 17-10-2026, 8:10.
Rudi
Post17-12-2004, 11:04    Subject: Run 1Z without muffler? (SEO optimized) Quote
I guess I was lucky. The fracture was right at the MSD (most superior dorsal) and extended from there to...
The brake force limiter is still a component, which means that the heat is dissipated through the turbulence.
'It's been distributed quite well. The cavity preservation and underbody protection are still present.'
where they belong.
Best regards, Rudi.
Translated on 17-10-2026, 8:12.
Gremlin
Post17-12-2004, 11:21    Subject: Run 1Z without muffler? (SEO optimized) Quote
I strongly advise against riding without an exhaust silencer.
We often see colleagues like that in the workshop... everything from melted underbody protection to rear bumpers in a 'Colani' design.
Extremely risky!
CU Gremlin.
Translated on 17-10-2026, 8:13.
Brake force limiter ???
"Don't worry, my colleague 'Mark 20' is in the engine compartment and controlling it from there."
Rudi, if your tractor is newer, why doesn't it have ABS?
I thought that was already standard practice.
Nevertheless, I would avoid doing that without using an ESD-safe environment.
Rudi
Post17-12-2004, 11:50    Subject: Run 1Z without muffler? (SEO optimized) Quote
Hi Martin,
The ABS series was only available from model year '97 onwards. Mine was first registered in May '96 and only has the CL trim level icon_cry.gif.
Best regards, Rudi.
Translated on 17-10-2026, 8:14.
Jan03
Post17-12-2004, 12:28    Subject: Run 1Z without muffler? (SEO optimized) Quote
Well, I also thought this part would last forever. It still looks pretty good overall, except that the pipe is completely broken right at the front, near the exhaust manifold. But I believe this was the first exhaust manifold it had (the car was manufactured in 1994 and has 180,000 km).
I think I'll just skip that and not bother driving around looking for an ESD. I'll just buy a new one today, even though it's going to be twice as expensive (because the stores around here really inflate their prices).
Thank you very much for your help!
/Jan
Translated on 17-10-2026, 8:15.
DocSnydor
Post17-12-2004, 12:57    Subject: Run 1Z without muffler? (SEO optimized) Quote
Can't you just temporarily fix it for now? It doesn't have to be airtight, it just needs to hold together so that the main exhaust flow can pass through again...
Translated on 17-10-2026, 8:16.
BlauBaer
Post17-12-2004, 13:41    Subject: Run 1Z without muffler? (SEO optimized) Quote
The ABS series was only available from MJ '97 onwards. Mine was first registered in May '96 .
mine is from June 1996, but according to the documents, it's a 1997 model year, and it doesn't have ABS yet icon_cry.gif.
best regards
Translated on 17-10-2026, 8:17.
Post17-12-2004, 14:38    Subject: Run 1Z without muffler? (SEO optimized) Quote
Then it must have been an optional extra for my car.
EDIT: doppelwobber.de confirms: September '96 ABS for all.
I always thought that ABS was available from the facelift models produced in 1996.
Or maybe it was included in the "Europe" package.
I have a CL Vari Europe model with a few extra features.
He should really take a look at his exhaust pipe, because the rest of the exhaust system is already new (all of this just because of the flexible pipe... icon_sad.gif).
Translated on 17-10-2026, 8:18.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Door Lock Malfunction: A6 4B Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Run AXR without LLM Diesel Engine Technology
No new posts AFN Operation Without Needle Lift Diesel Engine Technology
No new posts Garrett 2052: Run Turbocharger Without Water Cooling Diesel Engine Technology
No new posts Muffler: Buy Exhaust Silencers Online Diesel Engine Technology
