Ignition Switch Wiring & Glow Plug System
zpeedster
Post12-12-2004, 15:41    Subject: Ignition Switch Wiring & Glow Plug System Quote
I urgently need the wiring diagram for the ignition switch from a Passat 35i B4, manufactured in 1994, with a 66kW 1Z TDI engine, as I am currently doing some modifications. I hope someone can help me.
I actually already have the ignition power, ground connection, and starter motor. However, I should know how the glow plug system is activated; it must be connected to the ignition switch somewhere, or have I been searching in vain all along?
Okay, hopefully I'll get the ignition switch wiring diagram and the control signals for the glow plug system.
Perhaps I'll need to disconnect the preheating system from the central electrical system in the footwell of the driver's side.
Translated on 16-08-2026, 19:34.
Post12-12-2004, 20:37    Subject: Ignition Switch Wiring & Glow Plug System Quote
zpeedster wrote:
The ignition switch urgently needs to be checked for proper wiring/connections.
What kind of German is that, and what tone is it using icon_question.gif?
zpeedster wrote:
...shouldn't it also be connected to the ignition switch, or have I been searching in vain all along?
Controlled by the engine control unit (temperature and speed dependent).
zpeedster wrote:
So, hopefully I'll get the wiring diagram for the ignition switch and the control signals for the glow plug system.
Perhaps I will have to remove the preheating system from the central electrics in the footwell of the driver's side.
See point number one!
So: If you're really looking for help, you should change your tone and describe what you're trying to do or what your problem is. Otherwise, it will be difficult to find someone who can or wants to help.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 16-08-2026, 19:37.
zpeedster
Post12-12-2004, 20:45    Subject: Ignition Switch Wiring & Glow Plug System Quote
Okay, I'm sorry; it happened during the hectic process of renovating. The tone was a bit inappropriate.
I would like to start my engine remotely. To do this, I bought a remote starter module from CarGuard (inexpensive and new).
For this, I need to have the necessary connections available so that I can connect everything as specified in the description and get the car back into a roadworthy condition.
I need to find out where the preheating system receives its signal. So far, I've thought it might also come from the ignition switch.
Translated on 16-08-2026, 19:39.
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts P0380 Error: Glow Plug System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ignition Problems: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Ignition switch not working Electrical Systems, Vehicle Electronics, Multimedia
No new posts Ignition Switch Audi A4 (1997) Stuck Transmission, Chassis, Body & Interior
No new posts Car Radio No Power? Troubleshooting Guide Diesel Engine Technology
