KW Systems Powerbox: No More Charging Issues:x
DerAlex
Post17-07-2002, 14:25    Subject: KW Systems Powerbox: No More Charging Issues:x Quote
icon_mad.gif I'm slowly losing interest icon_sad.gif.
For months, I've been searching in vain for a connector to connect a KW Systems Powerbox to a Golf IV TDI 90 hp engine (the connector at the VE pump has 10 pins).
The box is designed for two motors.
1: TDI engine, VAG, 1.9L, with 66kW or 81kW.
2: TDI engine, VAG, 2.5l, with 75kW or 110kW.
'Previously, this control unit was used in a Passat with a 90HP TDI engine. The connector at the VE pump has 8 pins. I'm not sure about the engine code, sorry.'
I was once told in this forum about the cost of the two 10-pin connectors for VW vehicles and their part numbers - thank you again.
I'm still missing the connector that connects to the wiring harness of the box; without it, I can't build an adapter cable icon_sad.gif.
I also have a photo of the plug, but I don't know how to insert it here icon_sad.gif.
Translated on 30-09-2026, 22:09.
Rudi
Post17-07-2002, 14:35    Subject: KW Systems Powerbox: No More Charging Issues:x Quote
Please attach the picture to an email.
Translated on 30-09-2026, 22:10.
DerAlex
Post17-07-2002, 18:56    Subject: KW Systems Powerbox: No More Charging Issues:x Quote
I just sent you the pictures. Thanks!
DerAlex
Post27-07-2002, 15:02    Subject: KW Systems Powerbox: No More Charging Issues:x Translating...
http://mitglied.lycos.de/nuralex1/hpbimg/stecker01.jpg
http://mitglied.lycos.de/nuralex1/hpbimg/stecker02.jpg
http://mitglied.lycos.de/nuralex1/hpbimg/stecker03.jpg
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Audi 80 Powerbox: Location & Connector Diesel Engine Technology
No new posts GRA Connector Not Compatible: Troubleshooting & Fixes Diesel Engine Technology
No new posts Twister LF by KW-Systems Diesel Engine Technology
No new posts KW-Systems P-Box with ALH Engine and Age-Related Issues Diesel Engine Technology
