Performance issues TDI 90hp, Part 3
Franz
Post25-07-2002, 0:24    Subject: Performance issues TDI 90hp, Part 3 Quote
Hello everyone,
I have already reported about my problem twice. I have now replaced the boost pressure solenoid valve, as you suggested. Regarding the loss of power at higher RPMs and the subsequent 'limp home' mode, this was a complete success. This error is now gone. 100 points. Although the solenoid valve was electrically okay, the valve function itself was defective. Thank you again for this tip.
Okay, but the problem persists. I was a bit too optimistic earlier. The performance is still severely lacking. It feels like driving a car with a naturally aspirated engine, although even that would run better. I was at a loss. I disconnected the mass airflow sensor (MAF) connector, and the power returned. I had previously measured the voltage at the MAF sensor, as reported before, and it was okay. I'm currently driving without the MAF sensor, and the car isn't running too badly. I'm completely confused because, without the MAF sensor, the car should be running much worse. As soon as I plug the LMM connector back in, the performance is poor.
'Question for you all: Could the LMM (likely mass measurement) be defective in this case?' That's quite strange behavior.
Best regards, Franz.
Translated on 05-07-2026, 22:11.
Georg_G
2012 Volkswagen Golf
Post25-07-2002, 22:01    Subject: Performance issues TDI 90hp, Part 3 Quote
Well...
Faulty mass airflow sensors often provide a lower airflow reading to the engine control unit (ECU) than what is expected in limp-home mode. Therefore, it is quite possible that your mass airflow sensor is defective. At least you performed the classic test for a faulty MAF sensor by disconnecting it and seeing if the engine ran better.
That, of course, contradicts your measurement of the voltage.
Try searching in this forum; I started a thread about how to jumper the MAF sensor connector so that it constantly outputs the maximum airflow signal. If the performance then increases again, this can serve as an indication that everything is now okay with your engine.
Best regards, Georg.
Translated on 05-07-2026, 22:13.
Franz
Post27-07-2002, 11:08    Subject: LMM Quote
Hello Georg,
where can I find this thread, approximately what date?
Translated on 05-07-2026, 22:14.
Georg_G
Post27-07-2002, 12:17    Subject: Performance issues TDI 90hp, Part 3 Quote
Okay, I'm ready. Please provide the German text you want me to translate.
Translated on 05-07-2026, 22:15.
No new posts TDI 90PS Performance Issues: Part 2 Diesel Engine Technology
No new posts Performance issue TDI 90hp Diesel Engine Technology
No new posts VW T4: Performance Issues & Solutions Upload
No new posts AEL Performance Issues: Troubleshooting Guide Diesel Engine Technology
