ASZ engine in Golf 2
Golfchriss
Post28-12-2004, 15:45    Subject: ASZ engine in Golf 2 Quote
Hello everyone,
I'm currently in the process of installing an auxiliary battery in my Volkswagen Golf 2. After many problems that I have already solved, two problems currently remain without a solution. icon_confused.gif
The drive shafts of the G60 or VR6 engines have a diameter that is too small on the transmission side.
The G4 ones don't fit into the wheel hub.
The second problem is the gearbox bearing!
Even after thoroughly studying the parts catalogs for various model types, I searched and found nothing suitable.
Has anyone done this conversion before and can help me with it?
The search function for existing posts wasn't very helpful here, or it didn't lead to the desired results (I didn't find anything).
Sure, here's the translation:
'Thank you very much in advance.'
Christoph
Arne
Post05-01-2005, 18:23    Subject: ASZ engine in Golf 2 Quote
Does the ASZ engine not have the same components as the 1.8T engines?
'A lot of those were installed in Golf 2s and Corrados, among other vehicles.'
arne
Golfchriss
Post06-01-2005, 10:50    Subject: ASZ engine in Golf 2 Quote
Hi Arne,
The main problem is the 6-speed transmission.
The gear flange, which houses the drive shafts, has a diameter of 113 mm.
The G60 and VR6 engines, but only with a 100mm bore.
I am looking for a solution to this.
Regards, Golfchriss.
andre
Post06-01-2005, 11:48    Subject: ASZ engine in Golf 2 Quote
Hi.
Here's a silly question: Can't you build an adapter plate there?
I vaguely remember my dad using something similar on a Porsche once. It was a 'plate' with two sets of holes (offset from each other), and the screws facing the transmission were recessed (using an Allen key).
No new posts Golf 5 / Audi A3 2004 BKC-Motor stirbt ab, startet nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4er Golf TDi... Motor/Kaufberatung ?!? Diesel Engine Technology
No new posts AGR am Golf 5 mit 105PS Motor Diesel Engine Technology
No new posts Which engine in the VW Golf IV!? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Leistungsverlust am Golf III AFN Motor Diesel Engine Technology
