Golf IV ALH: Does G60 flywheel & clutch fit?
Marzocchi
Post23-12-2004, 12:47    Subject: Golf IV ALH: Does G60 flywheel & clutch fit? Quote
I just took my Golf IV ALH with 110,000 km to the workshop because of strong vibrations, all the way up to the gear stick, starting around 2800 rpm. They believe it's either the pulley or, more likely, the dual-mass flywheel.
Da mein Gaolf ASV Düsen (110PS) hat und bald evtl. noch einen Chip bekommen soll möchte ich nun gleich Schwachstellen ausmerzen. Ausdiesem Grund soll wenn das Getriebe schon runter muss gleich neben der Schwungscheibe die Kupplung neu. MA question now:
Does anyone know if the G60 flywheel will fit on the ALH engine? The G60 has a single-mass flywheel, which is often used on performance-oriented AFNs because it is supposed to be much more durable than dual-mass flywheels.
Regarding the clutch: Can I use the clutch disc and/or pressure plate from a G60? Or are there better alternatives?
Thank you! Best regards, Bernd.
Golf IV - ALH - Erstzulassung 9/99
Translated on 30-09-2026, 1:49.
No new posts Golf IV 81KW - Kupplung rutscht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, defective window switch safety sensor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V BLS Simmering: Swing Replacement Diesel Engine Technology
No new posts Golf 3 1Z Engine: Fits Audi 80 B4? Diesel Engine Technology
No new posts Does this rim technically fit on a Golf V? Transmission, Chassis, Body & Interior
No new posts Does this catalytic converter fit a Golf with a 1Z engine? Diesel Engine Technology
