VALEO 120A Alternator - Replacement & Repair
titas
Post03-01-2005, 12:10    Subject: VALEO 120A Alternator - Replacement & Repair Quote
My VALEO 120A alternator in my Passat (90 horsepower, engine AHH) has a burned-out armature winding or a break in the winding.
Now, a new one is needed. I thought it would be better to replace it with a Bosch one right away.
For the model year change from 1998 to 1999, the BOSCH alternator was replaced by a VALEO unit. icon_mad.gif I assume this was due to cost reasons! ?
Can anyone tell me if it's possible to easily replace a VALEO part with a BOSCH part?
The original VALEO part has the VW part number 028 903 029E. I was offered a used BOSCH part from a Bora manufactured in 2000, with the VW part number 028 903 028E.
The problem is, I would have to have them sent to me without seeing them first, and I'm not sure if they are actually identical!!
Does anyone have any experience with this?
THANK YOU!
Titas
Translated on 23-10-2026, 20:37.
Post03-01-2005, 12:26    Subject: VALEO 120A Alternator - Replacement & Repair Quote
Here's some serious advice from me.
Nutz die Suche konsequent, dies Thema ( auch in Variationen ) hatten wir doch schon öfters. Mir liefert die Suche hierzu viele Ergebnisse. Sure, please provide the text you would like me to translate from German to English.
For example, you could also work on installing an air conditioning system. There are plenty of results for that on Google.
Translated on 23-10-2026, 20:39.
R.M.
Karma: +14 / -0   Thank you, like it!
Post03-01-2005, 12:46    Subject: VALEO 120A Alternator - Replacement & Repair Quote
Building an air conditioning system?
Wasn't this supposed to be a generator?
According to my search, there is still one manufacturer of glow plugs for VAG vehicles (e.g., G4 ALH).
Hitachi 120A, Model No.: 028 903 029G.
I can't say for sure whether all of them are interchangeable. Perhaps taking a look inside a TDI engine with a Bosch alternator might help. The dealership can certainly assist you if needed.
Translated on 23-10-2026, 20:40.
Post03-01-2005, 12:55    Subject: VALEO 120A Alternator - Replacement & Repair Quote
Sorry!
Das war so nicht gemeint und hier absolut falsch plaziert. Werde nächstesmal besser aufpassen. She belongs here.
and of course, it makes absolutely no sense here.
Translated on 23-10-2026, 20:41.
titas
Post03-01-2005, 13:43    Subject: VALEO vs. BOSCH Alternator: Comparison Quote
I've already been to the friendly place.
They advised me to reorder the VALEO part, as it is definitely the correct one.
Why the BOSCH system was replaced with VALEO, and whether anything was changed in the process, they wouldn't or couldn't tell me! icon_mad.gif
One potential issue is the pulley (with a freewheel). It's not clear whether other manufacturers offer a pulley with the same mounting and whether it would also align correctly.
It seems the only way to do it is to carefully compare the old and the new alternator before replacing it!
titas
Translated on 23-10-2026, 20:42.
chris11
Karma: +3 / -1   Thank you, like it!
Post03-01-2005, 16:23    Subject: Alternators: Valeo vs. Bosch Quote
titas wrote:
I've already been to the :xfriendly
place.
Why the BOSCH system was replaced with VALEO, and whether anything was changed in the process, they wouldn't or couldn't tell me! }
One potential issue is likely the pulley (with a freewheel). It's not clear whether other manufacturers offer a pulley with the same mounting, and whether it would also be perfectly aligned.
It seems the only way to do it is to carefully compare the old and the new alternator before installing the new one!
titas}
Was wäre, wenn der freundliche Mitarbeiter zu faul war, die part numbers of the attachments (freewheel, pulley, bracket) to compare in his spare parts catalog?
Or has VAG reached the point where, like with Opel, you can only choose a V-belt by measuring it with a tape measure held against your arm?
Maybe try a different brand of detergent sometime.
Christian.
Translated on 23-10-2026, 20:44.
Julian
Post03-01-2005, 18:21    Subject: VALEO vs. BOSCH Alternator: Comparison Quote
Was war der freundliche Mitarbeiter zu faul, um die part numbers of the attachments (freewheel, pulley, bracket) to compare in his spare parts catalog?
I also think so.
I would generally recommend Bosch alternators, because the replacement parts are usually available for a long time, they are often of high quality, and the carbon brushes are easy to replace. With many Valeos, this is not the case. I'd rather not say anything about Hitachi... icon_smile.gif
Translated on 23-10-2026, 20:46.
No new posts Alternator: Car Alternator Replacement & Repair Diesel Engine Technology
No new posts Alternator Damage: Causes & Repair Diesel Engine Technology
No new posts Alternator Carbon Brush Replacement Diesel Engine Technology
No new posts Alternator Problems? Get Fast Repair! Diesel Engine Technology
